Polk tl350 vs def tech procinema800??
Hello guys,
just like the title says i am looking into buying a satellite system and was wondering which is better.
I have not heard either but i know that for ht a lot of people prefer def tech. Wondering if i should take the crutchfield offer and get a free pair of atrium speakers or just order the procinema from def tech.
Any input would be greatly appreciated. Also how would the promonitor 1000 from def tech compare with rti4?
Regards,
eduardo
Regards,
eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Post edited by EDUBAG on
I've ProMon 600, which has the same tweeter as the 1000, but with 3.5" mid, instead of 5". and Rti8, which has the same tweeter as the Rti4
I can tell you that the DefTech sounds clearer in the high frequencies, especially for music. The tweeters in the Rti series are bright, but not in a good way. I am replacing my Rti set with Klipsch RF-52II this weekend. As you can see, I don't mind bright speakers, but the brightness from the Rti series is terrible for music.
I've not heard the TL yet, but if they use the tweeter from the LSI series, then I bet it should sound the same or better than the DefTech.
Between the TL350 and deftec 1000, this is a super hard decision. I'd have to listen them both in the same room to decide. -
bumpHT:
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
MIT EXP2 SPEAKER CABLES -
burpDARE TO SOAR:
