Question on Soundbar
AGrounds
AGrounds Posts: 1
I had a question about the Polk Audio soundbar. Is it possible to hook a receiver up to it? I was in Best Buy and the employees there did not have an answer and the back of the SoundBars only have a single mini input plug? Is there something I am missing or is it not even possible? Thanks alot, and im sure this is a stupid question I just have no idea.
  • dorokusai
    dorokusai Posts: 25,642
    edited June 2011
    Yes, it depends on the SBar but I would suggest hooking it up with the optical output from the AVR/Receiver or Television.
    What model were you looking at? All the User Manuals for the current product line are available here for download on PDF.
  • packetjones
    packetjones Posts: 1,059
    edited June 2011
    There are a few soundbars that connect to a AVR. Check out the surround 50.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • dorokusai
    edited June 2011
    If he's at Best buy it's either the SBar 3k, 6k or 360.
