PSW505 vs. WHAT?
I have a JBL Balboa 10 and I think it is getting ready to blow. I see the PSW505 is still available at a very resonable price but am concerned that this sub is going to blow the house down! I see nothing but 5 star reviews on the sub. Is there anything else that I should consider?
Post edited by wynn711 on
  • jbooker82
    jbooker82 Posts: 1,627
    edited June 2011
    Please remember the 5 star reviews heavily take in consideration of the price.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • wynn711
    wynn711 Posts: 7
    edited June 2011
    I understand that I can spend as much money as I want, but I am looking for the best bang for the buck?
  • B Run
    B Run Posts: 1,888
    edited June 2011
    It's a good bang for your buck sub, not going to blow your house down. For the money its definitely one of the better subs you can get, but if you up your budget it will not compete with HSU, Epik, SVS, Outlaw or Elemental Designs. It's all up to what you expect from a sub and what you can afford.
  • wynn711
    wynn711 Posts: 7
    edited June 2011
    Thanks for the information, I am no expert and have never heard of any of these brands!
  • codyc1ark
    codyc1ark Posts: 2,538
    edited June 2011
    I'd stick with the brands B Run recomeneded. Look closley at Epik, Outlaw and Elemental Designs, all have great reviews, do you have a max budget in mind even though you stated you can spend as much money as you want. (If thats the case, go with a JL and be done with it, for a very long time!) Look in to dual subs, also, if the budget and space permits, look at running dual subs. Good luck!
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2011
    wynn711 wrote: »
    On the AVS forum the Bic F12 is favored by a considerable amount to the PSW505. That's why I got the Bic and I absolutely love it.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • wynn711
    wynn711 Posts: 7
    edited June 2011
    I think that is more in my price range! Thanks
  • wynn711
    wynn711 Posts: 7
    edited June 2011
    I just spoke to Bic and they recommended the BIC/Acoustech H-100 instead. I see it has great reviews and just wondered if anyone had this model?
  • packetjones
    packetjones Posts: 1,059
    edited June 2011
    The bic 100 and the f12 are very similar subs. They are well reviewed. The best Polk sub in the price range is the 505.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • PolkClyde
    PolkClyde Posts: 662
    edited June 2011
    codyc1ark wrote: »
    Dual subs?,now that will bring your house down,right? No,I can't do that, don't have the space.but,I would love to have dual subs.
    PolkAudioClyde
  • wynn711
    wynn711 Posts: 7
    edited June 2011
    The more I read the more I go back to the Polk PSW505
  • ranger
    ranger Posts: 50
    edited June 2011
    I love my 505. Worth every penny I spent on it. One day I may try a high dollar sub but right now I am very content. It rumbles!
  • wynn711
    wynn711 Posts: 7
    edited June 2011
    Here is one reason in a review of the 505 and I am not seeing a dedicated LFE line on other units I have looked at????
    "This sub is one of the few in its price range that actually has an LFE input (Low Frequency Effects) in addition to LL & speaker-level. I you didn't know, LFE & Line-Level (LL) inputs both use an RCA connector. The difference is that the LFE channel carries only low freqs from source whereas LL carries the entire sound spectrum. The LFE goes straight to your sub's amp whereas LL first goes through your sub's built-in crossover and then from there to your sub's amp. If you plug LL into the LFE input, you'll be asking the sub reproduce the full sound spectrum. Not what you want, of course. Probably not a big deal whether you use one or the other. The Polk's built-in crossover is fine, i'm sure, but I'd rather do the crossing-over at the A/V unit level."
    My JBL Balboa has this and it makes a real difference in its sound so I have some concerns over some of the top end models not having this feature???
  • aboroth00
    aboroth00 Posts: 1,106
    edited June 2011
    wynn711 wrote: »
    Huh? LFE input makes no difference, you can bypass the XO by either turning the XO freq very high or just turning it off which is an option on many subs. Either way you'll be fine. Most setups have the XO set at the receiver and not at the sub anyway so an internal XO is often times moot.
    2Ch Tube Audio Convert
  • Turdpeterson
    Turdpeterson Posts: 3
    edited June 2011
    I just got my 505 and i must say its hits better then my old 15" cerwin vega 400watt, the bass is alot more punchy and fast and im hearing bass sounds iv never heard before. Think im gonna buy a second PSW505, also i like that it has a LFE port sounds cleaner to me
  • Zeros
    Zeros Posts: 940
    edited June 2011
    ROHfan wrote: »
    I also have a BIC 12 and think its a great sub for about $185.
  • Brunt
    Brunt Posts: 20
    edited June 2011
    BIC 12 in this price range from all I've read, just sold my PSW-505 on ebay so I can begin to scratch together enough for a better a sub.
