Cs1000p
Terminator1983
Terminator1983 Posts: 12
edited June 2011 in Vintage Speakers
I have a question regarding the cs1000p hookup. When using the line input on it are you supposed to hook that into your center channel preout on the receiver or subwoofer pre out? Any help would be greatly appreaciated!
Post edited by Terminator1983 on
    Tony M Posts: 11,589
    edited June 2011
    Center channel I would guess. It's a center channel, right?
    You're lucky to own one!!!:wink:
  • Terminator1983
    edited June 2011
    yeah I love that center and I was right i looked at the manual and its supposed to be in the center pre out on the receiver.
  • civilian
    civilian Posts: 357
    edited June 2011
    Using the pre-out you still need to hook up the the top set of binding posts to the center channel speaker outputs of your amp or receiver. I'd try it both ways to see what sounds better.
    ________________
    2 Channel-Denon AVR-4520/SDA 2.3TL's
    5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
