Timbre match RM7600
Tbone289
Tbone289 Posts: 661
edited June 2011 in Speakers
I have an RM7600/PSW505 5.1 HT setup that I've been enjoying for several years. I listen to music with these also and, while they are fairly musical, I would like to upgrade the fronts to towers for better performance.
I'm considering anything from the Monitor 70's up to current RTi models. What models will be best timbre matched with my rm4300 rears and rm4600 center so that I still get good HT performance?
Thanks.
2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
Post edited by Tbone289 on
  • 27dnast
    27dnast Posts: 255
    edited June 2011
    If you upgrade to larger L/R Front Speakers you should also upgrade your center channel to match the speakers you are buying. If you are looking at the Monitor series, the Cs1 or Cs2 center is where you'll need to look. The CS1 is selling for an affordable $75 on Amazon and the Cs2 (which is what you'd be better off with, considering you are looking at larger towers) is only $109 on newegg.
    Good luck
