Hi-Rez Audio
audiocr381ve
audiocr381ve Posts: 2,588
edited June 2011 in 2 Channel Audio
I just purchased some high rez audio from HDTracks.com. What software do you guys use to play your hi-rez audio from your PC's? I want to connect to my DAC via USB from my Laptop to hear true 96/25 files which my PS3 resamples down to 44/16.
As always, any help is greatly appreciated :)
Post edited by audiocr381ve on
  • Face
    Face Posts: 14,340
    edited June 2011
    J. River.
  • PrazVT
    PrazVT Posts: 1,607
    edited June 2011
    I use Winamp w/ the x64 ASIO output plugin. But I run an optical out from my X-Fi Titanium HD (in bit-matched mode) to the DAC and not the DAC via USB. There is also a kernel streaming plugin.
    Otherwise I know folks use Foobar as well, but I don't have alot of experience with it.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • coolsax
    coolsax Posts: 1,826
    edited June 2011
    I like using Media Monkey.. all players listed are good ones to use.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • nspindel
    nspindel Posts: 5,343
    edited June 2011
    I use a Squeezebox. So much easier than trying to get good audio, even digitally, out of a computer. Check out a Squeezebox Touch.
  • zingo
    zingo Posts: 11,258
    edited June 2011
    I use iTunes on PC which I know is not a favorite here, but it's easy and the remote interface is great.
  • audiocr381ve
    edited June 2011
    Squeezebox Touch seems the be the best digital solution. It outputs 96/24, has coaxial, and is a great media server. More money to spend :(
    Thanks guys!
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2011
    It will be interesting if, in addition to this coming Monday's introduction of iCloud, Apple announces that iTunes will also offer lossless and high-res files. The rumors have been around a couple of months now on this issue.
  • nspindel
    edited June 2011
    I don't think it's a rumor. I think they came out and stated a few months back that they intend to get into 24 bit music. Not sure I understand the motivation for them, though. Apple markets to the masses, and the masses ain't interested in high-rez.
    audiocr381ve, you can sometimes spot a used sb touch for around $220 if you keep your eye out. Once you go squeezebox you can start having some fun. Check out the Squeezebox Radio. Not an audiophile product, but a lot of fun on your nightstand!
  • inspiredsports
    inspiredsports Posts: 5,502
    edited June 2011
    nspindel wrote: »
    A couple years ago "the masses" weren't interested in anti-lock brakes or GPS devices or BDP's. I could go on . . .
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • nspindel
    edited June 2011
    But the masses don't own or care to own a device with which hi rez will make a bit of difference. The masses own iPods and $5 ear buds, and will see 24 bit as nothing more than a reason why they cant fit as much music on their portable players. The masses play 128kb mp3's, when lossless is available to them right now.
    I suppose the appeal of hi rez to Apple is that they already have the infrastructure to deliver digital downloads, and a massive customer base. So whatever incremental business hi rez brings is gravy, for very little overhead. I just find it a strange niche for them to be entering, because I've never seen them concerned with an audiophile clientele before.
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited June 2011
    Hi-Rez would be an awesome move for Apple. It's sort of akin to Microsoft beefing up the Windows/Office bloatware to soak up every bit of performance improvement in Intel processors, requiring bigger processors, allowing more bloated software, ad infinitum. Assuming hi-rez audio becomes easy to obtain for people's preferred genres and artists, if there is even a slightly noticable difference people will spend more for better hardware to get the good stuff.
