Setup question - onkyo 608 and monitor 70s
nolec5
nolec5 Posts: 42
edited May 2011 in Speakers
I couldn't pass up the deal on newegg and upgraded my front speakers. Replaced my current monitor 50's and CS1 Center with monitor 70s and cs2.
My question has to do with the receiver. When I get the new speakers and have them all setup....is there some sort of reset I should do on the receiver...to start from scratch? Or do I just run the audussey eq??
Post edited by nolec5 on
  • Geoff4rfc
    Geoff4rfc Posts: 2,480
    edited May 2011
    nolec5 wrote: »
    Congrats on your purchase. No need to reset anything. Just run audyssey for the new speakers and you'll be fine.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • nolec5
    nolec5 Posts: 42
    edited May 2011
    Great, thanks! I'm traveling for work so I don't have access to my receiver or current settings. I seem to remember having to set the speakers to large or small? Or maybe it was full?? Should I look at this or should audussey take care of this too?
    txcoastal1 Posts: 13,338
    edited May 2011
    If you are not running a sub set to large
  • Geoff4rfc
    edited May 2011
    I run a sub plus have my speakers set to large.
  • nolec5
    nolec5 Posts: 42
    edited May 2011
    Yes, I have a sub....PSW 125 12" sub
  • Geoff4rfc
    edited May 2011
    Probably the best thing you can do is to set it up both ways and see which sound you like best.
  • nolec5
    nolec5 Posts: 42
    edited May 2011
    So would I set the speakers to large, run audussey and then listen to the setup? Then change to small, run audussey and listen again?
  • Geoff4rfc
    edited May 2011
    nolec5 wrote: »
    Absolutely.
