Bellari Tube preamp for turntable- 180 shipped
artinaz
Bellari VP130 with all the accessories. I bought it from Amazon and used it for maybe 10 hours in the past year. Its time to clean up the toys that I am not using- so here goes.
One caveat- the manual says 15V for the power supply, but the power supply that came with this unit is 12V- it hasnt caused any problems for me- I mention it in case you go head-scratching.
It sells for about 250 or so new. I am asking 180 shipped within the US.
HiFi+ Review of Bellari VP129
I was surprised by how attractive and well balanced it sounded: smooth and warm, yet open and crisply detailed. The Bellari seemed to create a sound that was rich, natural and appealing. Surface noise was low, and the music emerged from a crisp, clean, quiet background. It was an excellent sound by almost any standards; one I was very happy to listen to.
Stereophile Review of Bellari VP129
The versatile [Bellari] VP129 looks great, and it sounded as good as it looks. It was quiet, and golden-sweet and liquid in the midrange, as you?d expect from a 12AX7-based phono preamp. I wasn?t expecting its top end to be so nicely extended, fast, and clean, or its bass to be so snappy, articulate, and extended. Every type of music I played through the surprising little Bellari sounded full-bodied and rich, yet detailed and crisply rendered. The Bellari VP129 gets my highest recommendation, and is the budget phono preamp I will now recommend for every genre of music?get a Bellari and a budget turntable, and I promise that your CDs will start to gather dust!
Post edited by artinaz on
Great little preamp here. If vinyl is all you listen to, you can connect this directly to your amp, dont need a separate preamp.
Hey, sorry for waking up this old thread, just wanted to check if this unit ever sold?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I'm pretty sure this is the one I bought. I like it a lot. I may be looking at going with a tubed pre-amp, so might not want a tubed turntable pre.. It will be next summer though before I would move it on.
