TL2 - how do I remove the base?
Black Cloud
Black Cloud Posts: 4
edited May 2011 in Speakers
Hi all,
I bought 6 TL2s based on advice I received here earlier, and now I'm mounting the satellites on the wall. Is it possible to remove the base of the speakers? There are two little screws on the bottom but removing them doesn't seem to do anything. The serial number is affixed to the bottom as well which hints that the base is not meant to be removed.
Any ideas?
Thanks,
Paul
Post edited by Black Cloud on
