Squeezebox Touch $239.99 shipped
dragon1952
dragon1952 Posts: 4,907
edited May 2011 in Electronics
I put this in the Clubhouse but probably should have put it here. I would hate for anyone wanting one of these to miss out.
Through Logitech website http://www.logitech.com/en-us/speakers-audio/wireless-music-systems/devices/5745
Use and apply coupon code logi_touch_52711 after you've added it to your cart. Only good for the 1st 100 uses. Use CC or PayPal.
Post edited by dragon1952 on
    heiney9 Posts: 25,427
    edited May 2011
    Anyone on the fence jump on this. I bought my Touch and Squeeze Radio with a similar coupon and it only lasts a short time before it becomes invalid.
  • jabrax
    jabrax Posts: 315
    edited May 2011
    Thanks for the heads up...Got one... Been on the fence for how i was going to control digital music through my dac. Im not even sure how this works, but for this kinda deal, worth a try... cant help but to break even if it doesnt work out... thank again :)
    TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
    Pre/Processor - Emotiva MMC
    Seven Ch AMP - Emotiva LPA
    Fronts - Tyler Acoustics 7U's
    Center - Polk LSIC
    Sub - DSWPRO600
    DAC - Music Hall 25.3CD - Marantz cc4001
    Blue Ray - PS3
    Speaker cables - Audioquest cv4 dbs
    Interconnects - MIT AVT1's
    Power Filter....Monster HTS 3500 MKII
  • packetjones
    packetjones Posts: 1,059
    edited May 2011
    So how does this unit work? I read about it watched a video or too but have some questions. Is this a handheld unit or does it have to stay on the shelf. It kinda looks like a docking station or something. if it stays on the shelf do u have to get up and add songs or build playlists or something?
    I am currently using my ps3 with a harmony remote and it works ok. Is this a step up?
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited May 2011
    It would basically take the place of your PS3, and it has its own remote. It's not a docking station at all, just a network device that plays internet radio, accesses music off of a PC or home server, or reads directly off an SD memory card or USB stick/drive. If the PS3 is working for you and you're going to keep using it in the same system, then you probably don't need this.
  • ESavinon
    ESavinon Posts: 3,067
    edited May 2011
    PS3 does not stream FLAC which is the preferred method for lossless audio. The squeezebox devices do.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • PrazVT
    PrazVT Posts: 1,607
    edited May 2011
    Well technically, if you're using something like TVersity, it'll decode on the server side and simply send the PCM to the PS3. So you can get FLAC and Apple lossless to your PS3 that way. That's what I did before getting a squeezebox.
    But the Squeezebox experience is better b/c you can use your android or iOS devices as remotes to browse / play your music.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
