Carver Amp opinion
gnoorts
gnoorts Posts: 20
edited June 2011 in Electronics
A local friend has offered to sell me his Carver AV-505. If I got it, the amp would be powering a pair of LSi25's, an LSiC, and a pair of LSi7's. Do you think this amp would be able to handle that kind of load?
I've search Google fairly extensively, but I could not find ratings for this amp. I know it is rated at 100 W/ch for 2 channel, and 80 W/ch for 5 channel, but those are both 8 ohm ratings. I know Carver's have a solid reputation behind them, but are the experts' opinions? :smile:
Post edited by gnoorts on
    nooshinjohn Posts: 25,928
    edited May 2011
    This amp won't have the guts to push an entire LSi set. I would look for a good deal on a Sunfire Cinema Grand instead.
    EndersShadow Posts: 17,704
    edited May 2011
    I concur.
    treitz3 Posts: 19,999
    edited May 2011
    You do not want to use that amplifier for this purpose.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited May 2011
    if I may ask.... how much is your friend letting you pay ?
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2011
    Not enough amp for your needs.
  • gnoorts
    gnoorts Posts: 20
    edited May 2011
    Haha, he offered to sell it for $200 and I definitely like the way it sounds. He has an older Klipsch system running off of it (no idea about the speaker models), using a Yamaha RX-V665 as the AVR with pre-outs. He's looking to get an Adcom GFA-7000 to replace his Carver.
    edited May 2011
    gnoorts wrote: »
    Klipsh are a MUCH different sound than your LSi's and are also much more effecient so they can do more with less power.
    I run a Carver AV-705x w/ some 15's and a LSiC and am willing to bet if I tried hard I could trip the amp.
  • bsoko2
    bsoko2 Posts: 1,449
    edited June 2011
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited June 2011
    ^^^ I believe Cfrizz has that exact amp; if so, her opinion would definitely be worth listening to.
    edited June 2011
    I also think this (or one of the other Sunfire Grand's) is what NooshinJohn has and has run his SDA's, LSi 15's (now mine :smile:) and a set of Magneplanar MMG's.....
