Mirage MM-6 Subwoofer - pair MX speakers
dee1949
dee1949 Posts: 1,425
edited June 2011 in For Sale (FS) Classifieds
- High tech designer solution for great audio. Like new - Beautiful high gloss piano black finish.......$275.00
- for those short on space. Great for office, desktop, bedroom or surround system. Add Mirage MX speakers below for total system.
- if you are considering a BOSE system...check these out. Bose is not in the same league in design, construction or sound.
Technical Specifications
* Speaker Type: Powered subwoofer with active & dual passive drivers
* Woofer: 6.5-inch (16.5 cm) Black anodized aluminum cone with inverted Ribbed Elliptical Surround
* Passive Radiators: 2 x 6.5-inch (16.5 cm) Black anodized aluminum cones with inverted Ribbed Elliptical Surround
* Amplifier Power: 800 Watts
* Frequency Response: 42Hz-200Hz
* Max SPL: 104dB @ 42Hz, ground plane, 1M
* Recommended Sub Crossover (w/MX speaker): 150Hz-180Hz
* Variable Low Pass Filter: 50Hz-200Hz, Bypass
* Phase Control: Variable 0o -360o
* Inputs: L + R Line in/Sub in
* Power Modes: Off/auto/on
* Dimensions (H x W x D): 8" x 8" x 8"
* Product Weight: 10.1 lbs (4.6 kg)
* Finish: High gloss black
- Product Dimensions: 8 x 8 x 8 inches
- More info below:
http://www.amazon.com/Mirage-MM-6-miniature-High-Performance-Subwoofer/dp/B001HRFINY
- price comparison:
http://www.google.com/products/catalog?q=mirage+mm-6&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&tbm=shop&cid=15003056610032062694&sa=X&ei=HAzdTYz_PILHgAfGsdAK&ved=0CCcQ8wIwAA&biw=1280&bih=575#
- also have a pair of Mirage MX miniature High-Performance Speakers: ..........$175.00 a pair
Even though it's the smallest speaker Klipsch have ever made, the MX delivers big, immersive music and
movie entertainment that will leave you in a state of utter disbelief. Whether you want to relax to
smooth tunes or host a movie screening, the MX speaker serves up some serious wow factor - immersive
sound that won't drown out your decor or intrude upon your everyday lifestyle. The MX is a
sophisticated speaker that perfectly demonstrates what's possible using all of today's incredible
technologies. In fact, its extremely high-performance drivers and components will blow you away, so
hold on tight.
* Speaker Type: MX ultra-compact Omnipolar? home theater speaker
* Amplifier Power: 10 to 100 Watts RMS/ channel
* Impedance: 8 Ohms nominal / 4 Ohms minimum
* Magnetically Shielded: Yes
* Frequency Response: 110 Hz - 20 kHz
* Sensitivity: 87dB
* Crossover Point: 3.5 Khz
* Components: Tweeter: 5/8" (16 mm) pure titanium hybrid
* Woofer: 2 1/2" (64 mm) high efficiency woofer with aluminum cone
* Connectors: Integrated push terminals
* Dimensions HxWxD (Inches): 4.04 x 3.2 x 3.54 (height with grille 4.33") Cm: 10.2 x 8.14 x 9.0 (height with grille 10.1)
* Weight: 1.455 lb / 0.66kg
* Cabinet Material: Ultra rigid polycarbonate enclosure
* Grille Material: Magnetic with black cloth
* Accessories: Integrated dual key-way mount (for wall & stand mounting)
....these are a current product and individual speakers can be added below:
http://www.amazon.com/Mirage-MX-miniature-High-Performance-Speaker/dp/B001N2TEZG
************************************************buy Sub and pair of MX speakers together for................$425.00
Post edited by dee1949 on
