Powering Rti A7, Csi A6, FXi A4
joshawchubby
hello I purchased polk speakers last year and finally set it up just this summer. Here are the list of equipment all hooked into an ONKYO TX-NR708 AV receiver:
1.) RTi A7;
2.) CSi A6;
3.) FXi A4; and
4.) DSW PRO 500
Now I have read the other article regarding LSi Series that it needs an external amp for better results. Does that suggestion applies to my equipment as well? . Btw, my room is 13x13. Thanks!
1.) RTi A7;
2.) CSi A6;
3.) FXi A4; and
4.) DSW PRO 500
Toshiba Regza LED 55XL700E
Onkyo TX-NR708
Polk Audio RTi A7
Polk Audio CSi A6
Polk Audio FXi A4
Polk Audio DSW PRO 500 Subwoofer
Onkyo TX-NR708
Polk Audio RTi A7
Polk Audio CSi A6
Polk Audio FXi A4
Post edited by joshawchubby on
joshawchubby wrote: »RTi A7
... read the other article regarding LSi Series that it needs an external amp for better results. Does that suggestion applies to my equipment as well? . Btw, my room is 13x13. Thanks!
Cheers tonySamsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
*soldered **Rob the Man (Xschop) LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & Mids - 981, connected w/Monoprice Premiere ICs
Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
In my current setup, I seem to be having a hard time getting the bass out of my A7, I even set them up to full band in contrast to the suggestion of polk to set all speakers to small when there is a sub. .So by adding the external amp,I am sure that it will solve this problem ??? I am total newbie on Home theater, And I am still learningToshiba Regza LED 55XL700E
Onkyo TX-NR708
Polk Audio RTi A7
Polk Audio CSi A6
Polk Audio FXi A4
Polk Audio DSW PRO 500 Subwoofer -
What are you crossing at?Political Correctness'.........defined
President of Club Polk -
Hmmm in movies, my polks sound definitely awesome. Music, on the other hand, does not perform well as with the movies. I am thinking that if I add power to it maybe it would sound good? Or will I be better of with a stereo amp??Toshiba Regza LED 55XL700E
Onkyo TX-NR708
Polk Audio RTi A7
Polk Audio CSi A6
Polk Audio FXi A4
The Rti A7 are set at 50HZ ; CSi A6 - 70HZ ;FXi A4- 80 HZ; Subwoofer - 120HZ . .Toshiba Regza LED 55XL700E
Onkyo TX-NR708
Polk Audio RTi A7
Polk Audio CSi A6
Polk Audio FXi A4
Hopefully some of the HT experts (I'm not) will be around soon.Political Correctness'.........defined
Here is how I have gotten the most bass out of my 7's.
Go through and run the auto setup. Write down the sub level, and distance after completing the auto setup.
Then go back and rerun the auto setup but run it with subwoofer set to none. That way you trick the autosetup. It should set your towers to full range and adjust the eq accordingly. Then go back and turn the subwoofer on and re input in the distance, and level. Leave the towers set to full range and turn the double bass on.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
joshawchubby wrote: »In my current setup, I seem to be having a hard time getting the bass out of my A7
Please forgive my long windedness.
How many hours do you have on them? Right out of the box they're a bit bright. Until they have 100+ hours on them, the upper mid thru mid treble tend to overwhelm the bottom. Over time, the upper end will soften & the low end will "loosen."
Also I'm not tuned in to your AVR's specs, specifically @ 4 ohms if its rated. If your AVR doesn't have a 4 ohm rating, this can also explain why you find them a "little lean in the bass." Read on.
At the risk of stiring up some people, I'll let a disinterested source say what I've known for over a year.
In post #41*, the OP writes "...there is -zero- high pass filtering on the midbass. It is playing everything."
* in the link below
http://www.polkaudio.com/forums/showthread.php?t=118120&highlight=RTiA7+mod&page=2
In other words, your L&R channels "see" 4 ohms below 125 hz! Sadly you won't get Polk CS to admit to any of this.
Right now I'm evaluating my handy work to actively bi-amp one channel. This weekend I'll replace the Sub's XL280 with a Belles 1 Series w/its warmer bottom.
On a side note: how do ya like your 55" Regza?!! my next video upgrade.
Hope this helps, tonySamsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
From what I've read, your sub and your A7s shouldn't be outputting the same low frequencies. In my experience it tends to make things worse - ie they cancel each other out. For movie content I settled on the 80Hz crossover from the A7s to the sub. I let Audyssey keep the crossovers of the center and the surrounds to whatever it wanted (60 and 80 Hz i think).
Based on the Audyssey article I read, it makes sense. But YMMV.ALL BOXED UP for a while until I save up for a new place
Home Theater:
KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
2 Channel:
Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs -
Thanks for the response guys . . .:) It really helped. I played around my settings after audyssey . .Now, my only problem is when playing in stereo mode. It seems really lackluster compared to playing movies. I have read that the onkyo Tx-nr 708 receiver is not that good in stereo and a dedicated stereo amp is the way to go for 2 channel music. I am just curious, what would be the best indication that an external amplifier is needed? I did my research but I wanna know with you guys what would be the best indication that an external power amp is needed? I am looking at the emotiva xpa-3, and just by the looks of it, it is already a winner .
@ gp4jesus
Regarding the Toshiba 55XL700, Yeah, best tv I have ever had . In my opinion, this Led TV is plasma-like in visuals . The design (looks) just isn't great though. It is bulky, but the toshiba guy said that it is bulky due to the audio system it hasToshiba Regza LED 55XL700E
Onkyo TX-NR708
Polk Audio RTi A7
Polk Audio CSi A6
Polk Audio FXi A4
joshawchubby wrote: »I am looking at the emotiva xpa-3, and just by the looks of it, it is already a winner .
I got the XPA-5 earlier this week and it made a huge improvement in stereo music playback as well as home theater for me. I put on some smooth jazz last night and turned up the volume to just -30db, and it was filling my 12x30 ft room with great sounding bliss!
If you can afford to spend more I'd check out the higher end amps, but the Emotiva is no slouch. Especially at its low price in comparison to others.AVR: Onkyo TX-NR808
Amp: Emotiva XPA-5 200 watts x 5
Fronts: Polk Monitor 70 Series II
Center: Polk CS2 Series II
Surrounds: Polk Monitor 70 Series II
Sub: HSU VTF-2 MK4
HDTV: 73" Mitsubishi DLP-73740 3D-ready
PS3, 2x XBOX 360, Wii U, Gaming PC. -
Emotiva I think is just a wishful thinking for me as I live in the Philippines and there is no distributor here and the shipping costs in addition to the regular price would in effect triple the price. But I hope I could get one.
Btw, Your room is significantly larger than mine. Mine is roughly 13 x 13 as compared to yours(12x30). So, the addition of the XPA-5 significantly improved the sound at your normal volume levels? or you have to crank up the volume to hear the difference? Anyway, What receiver are you using?Toshiba Regza LED 55XL700E
Onkyo TX-NR708
Polk Audio RTi A7
Polk Audio CSi A6
Polk Audio FXi A4
joshawchubby wrote: »Regarding the Toshiba 55XL700, Yeah, best tv I have ever had . In my opinion, this Led TV is plasma-like in visuals.
We LOVE the video quality! I've watched TV @ 45-60 degrees off center w/zero fade!joshawchubby wrote: »It is bulky, but the toshiba guy said that it is bulky due to the audio system it has
In the amp department, have you considered the used market? Rotel RB-993 & Adcom 5503 killer 3 channel amps. 3 ch amp combos: Rotel RB-991/992 or RB-1091/1092.
But don't take my word for it. Read Rotel reviews.
cheersSamsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
joshawchubby wrote: »Emotiva I think is just a wishful thinking for me as I live in the Philippines and there is no distributor here and the shipping costs in addition to the regular price would in effect triple the price.
That's called a blessing in disguise. So, what are your choices in the Philippines?Political Correctness'.........defined
joshawchubby wrote: »Hmmm in movies, my polks sound definitely awesome. Music, on the other hand, does not perform well as with the movies. I am thinking that if I add power to it maybe it would sound good? Or will I be better of with a stereo amp??
The key to getting the best 2-channel stereo performance from your AVR is via either Direct Mode or Pure Audio Mode. This would be enhanced with the addition of external amplification. Have you tried these modes?
