Sennheiser HD600 + NAD c375bee question
PrazVT
PrazVT Posts: 1,607
edited May 2011 in Electronics
The NAD integrated's headphone section has a 68 ohm impedance while the HD600s are 300 ohms.
2 questions -
1 - Is it correct to assume that the headphone jack impedance being much lower than the headphone impedance is a good thing?
2 - Anyone have any experience using a NAD integrated's headphone jack w/ these more expensive headphones? I have a pair coming in tomorrow - hoping I can avoid having to buy a separate headphone amp.
My sister's been giving me crap for making too much noise w/ the LSi9s in the evenings so I decided to upgrade my HD555s.
Thanks!
- Praz
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups.
Post edited by PrazVT on
  • george daniel
    george daniel Posts: 12,096
    edited May 2011
    Try it and see-- since you are powering one set--you should be fine.
    No experience with the NAD--but I powered a set of 600's,,then 650's with a Audible Illusions L-1,the I used a little Creek headphone amp too--you should be fine.
  • PrazVT
    PrazVT Posts: 1,607
    edited May 2011
    I'm hopeful because my HD555s sound a hell of a lot better w/ the NAD Integrated than they ever did w/ anything else before that (ie. avr). So that's my point of reference.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • hoosier21
    hoosier21 Posts: 4,415
    edited May 2011
    plug them in, it will work fine.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • PrazVT
    PrazVT Posts: 1,607
    edited May 2011
    Thanks!
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • george daniel
    edited May 2011
    you are welcome--enjoy:smile:
  • PrazVT
    PrazVT Posts: 1,607
    edited May 2011
    You guys were right I think :) These headphones sound awesome w/ the NAD. I'm listening to the new Cars album and the clarity and bass is just beautiful. They probably need to be broken in ..but this is a great start.
    ...and for the "it didn't happen unless..." crowd....
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
