Reverse osmosis
doggie750
doggie750 Posts: 1,160
edited May 2011 in The Clubhouse
Kinda need u guys to direct me where to purchase a nice one for the kitchen or can I just get the one from Costco? I believe 3stage is sufficient. :confused:
The RO will be distributed to ice maker (5ft away), a counter dispenser (1-2 ft), and a filler faucet (5ft away). My assumption that I need at least 2 ROs to supply all the output.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • Jstas
    Jstas Posts: 14,849
    edited May 2011
    What are you talking about? Reverse osmosis is a term used to describe an action, not an object. You can't have 2 or 3 reverse osmosis.
    Unless you are referring to a reverse osmosis water filter?
    Expert Moron Extraordinaire
    pitdogg2 Posts: 25,772
    edited May 2011
    ever thought about deionization? RO is great but waste's a lot of water in the process. YOu can get the same results from DI without the waste water.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited May 2011
    where do you live ?
    Is there a problem with the water supplier ?
    My next door neighbor is public water expert and does not
    think any filtration is really needed but it is specific to the locality.
  • stuwee
    stuwee Posts: 1,508
    edited May 2011
    where do you live ?
    I use a Aquapuration DI-220, 2.5 by 20 purifier, pricey at about $200, and I still use a Brita filling station after that for my bottled water for the house, it's just nasty stuff we get here in Tucson from the infamous CAP system of garbage they call water in the desert, Yuck! http://en.wikipedia.org/wiki/Central_Arizona_Project
    I got spoiled living in NYC, their water is awesome!
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • ESavinon
    ESavinon Posts: 3,066
    edited May 2011
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
