Tell me if there is a Tube Conflict
dhart86
dhart86 Posts: 1,594
edited May 2011 in Electronics
Please help me understand. I just purchased a Wright WLA 12a pre-amp from the respected George Daniels. It should be on its way to its new home. However, this is my question.....I have a DAC that uses 6922 tubes and the Wright pre- uses 6sn7 tubes. If I connect this Dac (6922)to that pre- (6sn7)will it distort the SQ or can these pieces exist in the same chain?
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
    heiney9 Posts: 25,447
    edited May 2011
    There is no compatibilty issue with the different tube types, but you may or may not prefer the sound of both in the chain. I'd try them together and then seperately for an extended period of time to see which sound you prefer.
    There are not rules about how many tube pieces you can have in the chain. Just like anything else it's all about the synergy of the parts coming together. As a very general rule of thumb at some point you can have too many tubes in the mix and it can affect the sound in a negative way.
  • zingo
    zingo Posts: 11,258
    edited May 2011
    What DAC are you using?
  • dhart86
    edited May 2011
    heiney9 wrote: »
    Thanks H9! My question may sound stupid to some, but I thought i'd b better to ask than to do somethin stupid. You always give out good information.Thanks
    Jake my DAC is a Lite Audio Dac 60 modded by Pacific Valve
    Main Rig:
    Second Rig:
  • george daniel
    george daniel Posts: 12,096
    edited May 2011
    Try the pre first-- get accustomed to the sound,,the add the buffer,,,thatrs what I would do anyhow--ymmv.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    I believe George's approach is a smart way to ease into it without really starting to overdo it all. I've seen a couple people on here historically just go tube crazy for absolutely no reason except they thought that if a tube sounds good in one place, it must be needed everywhere. It's embarassing but when you have the 0% APR or less actual audio experience, you do odd things at times...then again, to each his own.
    Take your time, relax, enjoy and just listen. The rest will fall in place if you keep sitting instead of walking around looking for nulls, the ceiling and the UPS guy.
  • george daniel
    edited May 2011
    Try the pre first-- get accustomed to the sound,,then add the buffer,,,that is what I would do anyhow--ymmv.
    If I could only spell.
  • dhart86
    edited May 2011
    Thanks George,,sounds like a sensible approach. I'm sure I'll have questions later. I'll be sure to contact you when I do.
    Main Rig:
    Second Rig:
  • dhart86
    edited May 2011
    dorokusai wrote: »
    Gotcha dorok
    Main Rig:
    Second Rig:
