Wire length?
edited May 2011 in Speakers
I plan on ordering 12 awg wire tomorrow at Monoprice........I need to know if the wire length needs to be the same?
Front left is 40ft--right front is 30 feet--center is 35 feet...do I need to make all length at 40 feet?That way the signal gets to speakers at exact same time..right?
If not then i can save some cash and get less wire?
Please explain why or why not....if you have the knowledge and time PLEASE
16' x 12' Man Cave :smile:
Onkyo TX-NR1008 9.2 AVR
Polk Monitor 70's--Mains
Polk Monitor CS2--Center
Polk Monitor 30's--L/R Height's & L/R Wide's
Polk Monitor 30's--L/R Side Surround
Polk Monitor 30's--L/R Back Surround
(3)BIC Formula-12--Sub's
(4)Aura Pro Bass Shakers with Crown XLS 1000 amp
Emotiva-XPA-3 AMP for L/C/R
Epson 8100--1080p LCD projector
120" Elite Screen-- High Contrast Gray
Sony BDP-CX960--400 disc BLURAY player
Sony DVP-CX995--400 disc DVD player
XBOX 360 & PS3
Post edited by S T R Y K K E R on
Welcome!
    edited May 2011
    The speed at which electrical signals pass through a wire makes your question moot. 5 or 10 or 15 feet will not make a difference to your ears...you're fine at any of those lengths even if they are different. For all practical purposes the speed is instantaneous and simultaneous.
    You're good! Think of a telephone call to China or Japan...now there's some 'distance' but there really aren't any problems in communication.
    Good Luck!
    cnh
    edited May 2011
    For runs that short, it's not necessary to have them the same size. I have different lengths for my surround speakers. 30 feet for one and 45 feet for the other and no audible difference. It's different when you have something like 300 feet for one speaker, and 12 feet for another. For extremes like that, same size runs are more necessary.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
    edited May 2011
    Thanks I'll order 300 ft tomorrow.....
    XBOX 360 & PS3
Welcome!
Welcome!
