New Living Room Home Theater Build, Need input and ideas
Hey guys. I am planning to start putting together my new home theater system in my living room. I need your input on what gear I should look into and if it would be worth buying any sound trapping materials to put in the corners or the walls.
I posted a video that shows the room and my ideas about speaker placement and what I could do to help the sound quality by adding some sound deadening to the corners.
Please watch it here-->http://www.youtube.com/watch?v=udeLujNmfu0
Here is the gear I have selected so far.
Display - LG 250PK 60 inch Plasma
Mains - Paradigm Studio 60s v5
Center Paradigm Studio 590 v5
Rears Paradigm Studio 20s v5
Subwoofer - undecided
AVR - undecided
AV Stand - undecided
For sound treatment, I want to keep it simply and cheap.
Here are 2 items I was looking at buying ( no affiliation )
Corner Bass traps --> http://cgi.ebay.com/Next-CornerBassT...item4159b9c93d
For the Walls--> http://cgi.ebay.com/2-ACOUSTICAL-FOA...item27b9db2765
I would love to hear any ideas you guys have. Thanks!
AVR - undecided
My System
Pre/Pro - Integra DTR 40.2
Amplifier -Parasound 2205a
Paradigm Studio 60s V5 Mains
Paradigm Studio 590 V5 Center
Paradigm 20s - rear ( Wanted)
SUB - SVS PB12-NSD
LG PK250 60inch Plasma
SUB - SVS PB12-NSD
Post edited by neokeelo on
Your links take me to items that have been removed so i don't know what you tried to link us to.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
Sorry about that, I can't find the button to edit my original post.
http://cgi.ebay.com/Next-CornerBassTraps-Acoustic-Foam-4-pak-4-2-units-/280678222141?pt=LH_DefaultDomain_0&hash=item4159b9c93d&clk_rvr_id=233401709867
and the foam http://cgi.ebay.com/2-ACOUSTICAL-FOAM-WEDGE-12-x12-Sound-Proof-WALL-PANEL-/170621871973?pt=LH_DefaultDomain_0&hash=item27b9db2765&clk_rvr_id=233403100520My System
SUB - SVS PB12-NSD
LG PK250 60inch Plasma -
Here is a picture of the three front speakers. I am going to build a stand for the center and place it above/behind the TV.
For the subwoofer, I found a local guy selling his SVS PB12-NSD (older 325watt BASH Amp Version) for $450. So I thought that was a pretty good deal considering my room is not that big. Comes with 3 year transferable warranty as well.
It should help me put more money towards a quality pre/pro and interconnects and room treatments.My System
SUB - SVS PB12-NSD
Hang the tv on the wall, leave the center on the stand. Looking good so far.Shoot the jumper.....................BALLIN.............!!!!!
alright,
learning opportunity here i would like to seize.
what is a interconnect? is it just the proper way to connect two separate lengths of speaker wire or what?
thank you all for your wisdom.
esr:biggrin::biggrin:AVR: Sony 5600ES
Center: CS2II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
Front: Monitor 70 II (Clarity Caps PX, Perfect Lay coils, Mundorf resistors)
Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
Rear Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
More to come :biggrin: -
Sherardp, I can't hang the TV, I'm renting the house. I would rather move it up a ft to have bigger picture anywayMy System
SUB - SVS PB12-NSD
Esreuter, Interconnects are the cables you use to connect your pre amp / processor to your amplifier. Info here --> http://en.wikipedia.org/wiki/InterconnectsMy System
SUB - SVS PB12-NSD
Perhaps an entertainment stand would work for you. One thing I see that may be an issue is the size of your center channel."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
renowilliams wrote: »Perhaps an entertainment stand would work for you. One thing I see that may be an issue is the size of your center channel.
Your correct. I am building a custom black speaker stand for this. I will put the stand on the table or on the floor. I haven't decided yet.My System
SUB - SVS PB12-NSD
I went to the dealer today to pick up the DHC-40.2 but all they had was the DTR 40.2 so I got that one instead. It was a demo unit with full warranty for $800 so I couldn't say no. I also finally picked up the Parasound 2005a. This thing is a monster. I'm going to hook up the two main speakers tomorrow along with the sub and listen try it out. I don't have an audio rack yet but I will try to post some pictures tomorrow. I need to find a cheap yet strong AV stand for these two components. the amp alone is close to 90lbs and 22 inches deep.My System
SUB - SVS PB12-NSD
After looking at your video, I think that I would reverse your setup and put the tv and speakers where your couch is now."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
I would but since my computer is on the other side of the wall in the bedroom, I need the equipment to be as close as possible to run cables and a wireless mouse and keyboard. Right now the Only thing I will be using my TV and receiver for is my HTPC in the other room.My System
SUB - SVS PB12-NSD
does anyone have any suggestions for audio racks or a small Tv stand I can use as one less than 30 inches wide? I went to 5 or 6 stores and outlets around here and I can't find anyhting. the Parasound @2550a is w 19" x h 7" x d 19 1/2",My System
SUB - SVS PB12-NSD
If you don't bound the problem for us you might still get lucky and get some really good suggestions...but perhaps a little more targeting information would help those of us in the peanut gallery...Current polk speakers:
Family room 5.1: TC265i R/L, VM10 Center, RC65i surrounds (couldn't match the TCs)
Basement non-dedicated 7.1 HT: SDA-CRS+ R/L, 255c-LS Center, LSiFX surrounds, RC80i in-ceiling rear surround, plus Wharfedale 12" sub (some day I'll get around to building 15" F-20 sub). -
Sorry for not being specific enough. Actually I am trying to decide if it would be better to buy a large TV stand that could support my 60 inch plasma and the amp and receiver and large center channel. Whatever the model I need it to be the " open air " type so that the components can breath easily. This might be the better option instead of trying to build a custom center channel stand and buying a separate a/v stand.My System
SUB - SVS PB12-NSD
I decided on this model. I think I can get everything inside of it and use the current tv stand as a coffee table. http://www.us-appliance.com/bsf5400.htmlMy System
SUB - SVS PB12-NSD
