Measuring dc voltage at speaker output
DON73
DON73 Posts: 516
edited May 2011 in Electronics
I'm sure there was a thread about measuring DC voltage at an amplifiers speaker terminals but I can't find it. If you can point me in the right direction please do so.:smile:
If there wasn't one and you're a techie please start one.:smile::smile:
TO ERR IS HUMAN. TO FORGIVE IS CANINE.
Post edited by DON73 on
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    What do you need to know aside from using a VOM?
  • FTGV
    FTGV Posts: 3,650
    edited May 2011
    Multi meter set to DC milivolts range.One probe on each binding post with no signal.
  • skrol
    skrol Posts: 3,462
    edited May 2011
    This link from AK may be helpful.
    http://www.audiokarma.org/forums/showthread.php?t=5634
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • DON73
    DON73 Posts: 516
    edited May 2011
    The two multimeters I use have digital readouts and when they're turned to DC voltage there are four zeros with the decimal point set at 10ths. MV appears on the right side of the readout so it seems that any reading would be in mv. A reading of 2.0 would be 2mv as I understand it. The instruction book doesn't fully explain the readings.
    I don't use a vom often and when I do it's for continuity and battery checking. I really do need some help whether it's how to read a vom or where I can find what I need to know to read the digital meter I have. I appreciate all suggestions you have. Thank you.
