Best CD-R for music
Ern Dog
Ern Dog Posts: 2,237
edited May 2011 in Electronics
It's time to buy more CD-R's because I'm out. I have been using Sony Music CD-R's and have been dissatisfied with them because many of those have this grungy hissy/static sound after awhile. I have one CD-R that I made last year that I can no longer listen to because this static is getting worse.
So, can you recommend another brand that is inexpensive because I need a 20-30 pack. Also what does it mean when it says 52x or 32x or 40x write speed. Is it better to have a higher write speed or a lower one? And when I say better, I mean the highest quality recording, not fastest.
Post edited by Ern Dog on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited May 2011
    I've never had problems with Memorex CD's back when I used to use them. In fact, I accidently found some when I went through some old boxes of car parts.
    I still use some of my burned CD's in my car and hear no static/hiss that you describe, and no I'm not running a factory system (look at my sig).
    Anyway, for best results you should record your CD's at a much lower speed than 'maximum'.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    heiney9 Posts: 25,440
    edited May 2011
    I usually buy Verbatim when they are on sale. Sometimes it's just a compatibility issue with the burner. I've used Sony, TDK and Verbatim for years with zero issues. Try a different brand.
    As far as write speed of the disc, it's meaningless in relation to sound quality. The computer program you use and proper set up of the cd drive are what affects sound quality
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited May 2011
    There are actually only a couple of companies that make CD-R's. I have Sony, Memorex, and Verbatim on hand, all are made by CMC magnetics. No way to know who makes them by the brand on the package, but there are programs you can download that will tell you. I avoid the ones that say made in China, and prefer the ones made in Taiwan. Never had static with any discs.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    I rarely make these anymore but I use MoFi. They are expensive compared to the others although damn sexy to look at.
  • Ern Dog
    edited May 2011
    Yep, those Mofi cdr look very cool.
    I decided to try this 5 pack Gold archive cdr's from MAM-A: http://www.amazon.com/gp/product/B004YQVOAG
    These have the Phthalocyanine dye which makes the cd more resistant to heat and light. I also hear that it makes the cdr's sound better. Check out this old thread by CP member Darqueknight: http://www.polkaudio.com/forums/showthread.php?t=50855&highlight=Phthalocyanine
  • dorokusai
    edited May 2011
    Cool ErnDog, those look like a viable alternative for sure.
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2011
    Like doro, I rarely make CD's anymore. Usually just copying something for my dad or nieces and nephews.
    I usually use Memorex for them and MoFi for myself. Is that wrong????
  • stuwee
    stuwee Posts: 1,508
    edited May 2011
    JVC/Taiyo Yuden's are highly recomended for CD-R/DVD-R's, Made in Japan, not that crap made in India most companies use to put their name on. I bought a bulk lot of 200 of the JVC/T Y's dirt cheap awhile back, sorry I can't remember where, search out some, you won't be sorry :smile:
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • phipiper10
    phipiper10 Posts: 961
    edited May 2011
    I'd also recommend Taiyo Yuden's silver or gold your choice.
    http://www.mediasupply.com/cd-r-media-taiyo-yuden.html
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • headrott
    headrott Posts: 5,496
    edited May 2011
    WilliamM2 wrote: »
    I avoid the ones made in China as well. But, I prefer the ones made in the USA or Japan. There is very little difference between the Chinese made ones and the Taiwanese made ones.
    Usually, older CD-Rs are better ones. TDK used to make some good ones (made in USA). Also, a company called Mitsui made (IMO) the best CD-Rs made (that I've used anyway). Unfortunately, Mitsui was baught out by another company and the quality of the CD-R's went down dramatically. If you can find some old "gold" colored Mitsui CD-R's. Get them. I have never tyried them, but Mobile Fidelity CD-R's may by very nice. I would check them out for current production ones. If you pass on those, get some older ones if you can find them.
    Also, for recording speed, I would set the recorder to the second from the slowest speed available. I have read that if you record in too slow a speed (i.e. 1X speed) the laser burns through the CD-R metal. If you record too fast, data errors occur. Hope this helps.
    Greg
    P.S. Just finished reading the rest of the thread and found others recommended the Mobile Fidelity CD-R's. Also, you (Ern Dog) suggested the MAM-A CD-R's, and that is the company that bought out Mitsui . Again, not as good as Mitsui used to be unfortunately. I have used Taiyo Yuden DVD-R's but not CD-R's and the DVD-R's seem very good. And as others pointed out "made in Japan". That's a viable option.
  • Ern Dog
    edited May 2011
    Thanks for the suggestions everybody.
  • jbooker82
    jbooker82 Posts: 1,627
    edited May 2011
    I havent burnt a cd in quite a while. I was using Black Memorex when I use to burn alot of cd's. That was when I was in high school and probably couldnt tell if it was a good cd or not.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • WilliamM2
    edited May 2011
    Other than Taiyo Yuden, I haven't seen Japanese made discs in years. I did prefer Japanese discs when they were still available locally, could probably still find them online.
    TDK sold the media end of their business to Imation in 2007, but I'm pretty sure they never made their own discs, Like most companies, they just re-badged them.
