Polyfill
RuSsMaN
Going to run two DXi 104svc in pre-fab box, slot ported, separate chambers for each woofer approx 1.5ft each. Putting it together tonight, how much fill do you think? Just enough to damp the back wave?
Cheers,
Russ
Cheers,
Russ
Post edited by RuSsMaN on
Oops, sorry I missed this one Russ. Guess I should pay attention to the sub section more often.
Im sure youve already got this figured out but Ill throw my $.02 worth in anyway.
Im not a huge believer in polyfill if your box is built to the proper spec. Polyfill would only be used if youre limited for space and have to under cut a bit on the air space, then youd use the polyfill to buy you some extra cubes.polkaudio sound quality competitor since 2005
