Subwoofer for this Setup
I have a 5.1 Setup consisting of:
Receiver: Pioneer VSX-920-K
Front: Monitor 70
Center: CS2
Rears: Monitor 50
I'm looking to add a Subwoofer to that setup. I bought a PSW111, but that thing is either broken or incompatible (turns on and off all the time, making a loud "thump"-sound) so I'm kinda not interested in buying another one. I've ordered a PSW10 for my Computer Speaker setup (consisting of Monitor 40's), but I'd like a subwoofer with LFE Input for my Home Theater.
Are there any non-polk subs that you would recommend? Ideally available in cherry or similar, as black looks awful in that room.
Front: Monitor 70
Center: CS2
Rears: Monitor 50
Post edited by mstum on
What kind of budget are you looking at? I think that'll help us get you pointed in the right direction.
For a tighter budget sub, if you can find the PSW505 it's a great one that would go well for what you are running. I've got it with a setup almost identical to yours, except I'm using M60's for surrounds. You can't go wrong for its $230 price point... if you can find one.AVR: Onkyo TX-NR808
Amp: Emotiva XPA-5 200 watts x 5
Fronts: Polk Monitor 70 Series II
Center: Polk CS2 Series II
Surrounds: Polk Monitor 70 Series II
Sub: HSU VTF-2 MK4
HDTV: 73" Mitsubishi DLP-73740 3D-ready
PS3, 2x XBOX 360, Wii U, Gaming PC.
