Mtx 801d
Systems
How would running two Momo 12's off of one of these things be?
Testing
Testing
Testing
Testing
Testing
... sketchy.
that's 400 watts at best per sub... more likely something like 375 per sub.
the 1501D would give you about 700 + per sub... which is much better.
while being rated at 500w each, the momo 12 can do more around 600-650 and its always good to have just a smidge more.
500 is fine, but 375 really isn't.
as such, id suggest the 1501D or last year's 81000D which can now be had on ebay for about 280 bucks new in box. same amp, just different models and difft features for "strapping amps" which you will not need, that is only for spl use when you want to put two amps on one sub.The Artist formerly known as PoweredByDodge -
pbd forgot to ask you something...
which momos you talking about?
theres 2 series now...which causes a lot of confusion
-Cody
