Stacking Blu Ray Player on top of AV Receiver
esatpil
esatpil Posts: 2
edited May 2011 in Electronics
Hi All,
Wondering if its okay to stack the very same Marantz units which I have purchased
http://www.cinenow.co.uk/articles/23002-ifa-2010-marantz-launches-18-new-products
Reason is that my shelf is not high enough the moment, however if I remove the centre shelf then it will fit comfortably.
There seems to be ventilation for the receiver heat.
I'm new to this AV world:smile:
Post edited by esatpil on
  • jon s
    jon s Posts: 905
    edited May 2011
    depends if the receiver generates heat... usually needs soem ventilation to cool it down... it's not the amps that heat up, it's the video processing board...
    EndersShadow Posts: 17,741
    edited May 2011
    esatpil wrote: »
    Hi All,
    You should be ok, but the louder you turn it up the more heat the reciever will generate so you may want to try and put something between the casters to add a bit more space between the reciever and DVD player.
    Nice choice in components btw.
    Oh and welcome to Club Polk
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited May 2011
    believe it or not my first fix for something like this was to go to Home Depot and got 4 x2in pvc fittings and I had black gorilla tape and it looked great before I got the right size rack.I don't know if you even have that much space, but something like this little fix is way better than nothing.
  • dragon1952
    dragon1952 Posts: 4,939
    edited May 2011
    If the receiver has vents on top I would not do it.
  • BlueFox
    BlueFox Posts: 15,250
    edited May 2011
    dragon1952 wrote: »
    That is the truth.
    My Sony 7100ES top is one large vent, but it was never hot to the touch. I put the matching 9100ES SACD on top and the two looked great. Would have made a great picture for an advertisement. Later I touched the AVR and it was hotter than Hades. I hated taking the 9100ES off since it looked so good, but at least everything still works 4 years later.
