Looking for sattelites to replace my Polk floor standing
vaq130
vaq130 Posts: 17
edited May 2011 in Speakers
Hi, would like to try a set of satellites vs my current floor standing set, reason prefer higher tones vs bass, what Polk or other satellites should I consider??
Post edited by vaq130 on
    tonyb Posts: 33,068
    edited May 2011
    Whats the budget ?
    Look into the new TL line of sats.
  • Topper
    Topper Posts: 403
    edited May 2011
    Definitely the new Blackstones !!
    The fun starts at the TL2 series but if you have the moolah for the TL3 range, definitely go with those :)
    tonyb Posts: 33,068
    edited May 2011
    Maybe Polk should hire Keith Stone, the guy who does keystone beer commercials, to do print ads for the Blackstones.:tongue:
  • possinger
    possinger Posts: 3
    edited May 2011
    I have asked this question before, but what is the difference between the TL2 and TL3 speakers? I can afford either set. I plan on buying the 550 Wi or the 440 Wi sub. I do appreciate the advice of the forman, but i would like to know if it is worth the extra money.
    13' X 13' X 8', Yamaha RX-A3000 receiver.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited May 2011
    possinger wrote: »
    TL3 has Polk's Dynamic Balance ring radiator tweeter. If you can afford it, buy it. It's better.
    To quote the literature:
    The incredible accuracy of the Ring Radiator Tweeter
    The Ring Radiator Tweeter has never been used in a compact loudspeaker before! You will hear the kind of incredible accuracy and detail (beyond even 30kHz!) you expect from a full-sized loudspeaker. The Ring Radiator Tweeter is found only in the world's highest of high-end loudspeakers, including our own award-winning flagship LSi and LCi Series speakers.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited May 2011
    The new line looks nice but have any of you heard em? I'd wanna take a listen before taking a dive but i don't think anyone carries Polk near me sadly.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
