My Next PURCHASE Swans 2.3BHT $51,080.00
Cmiller
Cmiller Posts: 108
edited May 2011 in Speakers
Swans 2.3BHT Ultimate Home Theater
Series Swans flagship series
Model Swans 2.3B
System Type 3-way 4th order vented box system
Drivers Configuration Woofer: PD6?4 (6.5")
Mid-range: DMO?16 (50mm)
Tweeter: RT1.3?16 (isodynamic ribbon tweeters )
Frequency Range 40Hz ~ 20kHz
Harmonic Distortion 50Hz ~ 20kHz ≤1%(2.83V/1m)
Sensitivity 90dB
Nominal Impedance 16Ω
Power Handling 10 ~ 500W
Other Parameter
Finished Clear piano lacquer finish over natural wood veneer
Dimension (W?H?D(mm)) 846?470?1940
Net Weight 112.5kg
Center Speaker:2.3C
General Data
Model Swans 2.3C+
Drivers Configuration Woofer: PD6?4(6.5")
Tweeter: TN28.1 (28mm dome tweeter)
Super Tweeter: RT1.3?2 (isodynamic ribbon tweeters )
Harmonic Distortion 55Hz ~ 20kHz ≤1%(2.83V/1m)
Sensitivity 90dB
Nominal Impedance 8Ω
Power Handling 10 ~ 320W
Other Parameter
Dimension (W?H?D(mm)) 1020?341?308
Net Weight 33KG
Surround Speaker:F5R
General Data
Series Hometheater Series
Model F5R+
System Type bi-di-pole surround speakers
Drivers Configuration Woofer: PD6?2 (6.5")
Tweeter: TN28.1?2 (28mm dome tweeter)
Frequency Range 55Hz ~ 20kHz
Harmonic Distortion 53Hz ~ 20kHz ≤1%(2.83V/1m)
Sensitivity 87dB
Power Handling 10 ~ 150W
Other Parameter
Dimension (W?H?D(mm)) 505?290?236
Net Weight 13kg
Subwoofer:2.3BSUB
General Data
Model Swans 2.3 SUB
System Type Powered 1-way 4th order vented box system
Drivers Configuration Woofer: PD15 (15")
Frequency Range 30Hz ~ 350Hz
Power Handling 260W
Input impedance 47KΩ
Input sensitivity 200mV
Other Parameter
Dimension (W?H?D(mm)) 726?726?666
Net Weight 53.5KGSwans 2.3BHT Ultimate Home Theater
Taylorsville, UT 84119 - May 10, 2011
Model Swans 2.3B
Sensitivity 90dB
Other Parameter
Net Weight 112.5kg
Center Speaker:2.3C
General Data
Model Swans 2.3C+
Sensitivity 90dB
Other Parameter
Net Weight 33KG
General Data
Model F5R+
Sensitivity 87dB
Other Parameter
Net Weight 13kg
Subwoofer:2.3BSUB
General Data
Model Swans 2.3 SUB
Power Handling 260W
Other Parameter
Net Weight 53.5KG
I wish...lol..I do wonder how good it sounds...
Uploaded with ImageShack.us
Samsung PN50B550 Plasma
Pioneer Elite SC-25
Pioneer Elite BDP-23FD
Adcom 7500 Amp-Panamax 4300 Conditioner
Polk RTi10's Fronts
Polk Csi A6 Center-Polk M60s rear Surrounds
Klipsch Synergy Sub-10 X2
Klipsch Synergy S-10 Premium back surround
Post edited by Cmiller on
