Heat Pump Hot water heater?
disneyjoe7
Thinking about getting one, anyone have this? Good or Bad...
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
Are you talking about the on demand units such as Rinnai tankless hot water heaters? If so, I have 2 in my house and I love them. They take up very little space as are super efficient on gas. They are expensive, but often times people don't realize just how expensive because based on the size of your water system, you might need multiple units. I had to have 2 because I am feeding 4 bathrooms and to be sure we'd have enough output with multiple showers running.
I particularly liked the tiny amount of space they take up. My 2 tank less heaters take up less room than a standard tank, which was important to me for finishing my basement.
One thing I learned was that they are very sensitive to gas flow problems. This past winter, the gas regulator outside my house was starting to stick and so the pressure wasn't quite right and neither would light off.
Hope that helps!
JustinFronts: Polk RTi A9's
Center: Polk CSi A6
Surrounds: Polk FXi A6
Sub: Epik Empire
Receiver: Onkyo TX-NR809
Amp: Emotiva XPA-3
Blu Ray: Panasonic DMP-BD210
Power: Monster HDP 2500
Monitor: Panasonic TC-P60ST30 -
Well never mind, I just googled Heat Pump Hot water heater because I never heard of it and it is a different animal than what I have... so disregard all of the above.Fronts: Polk RTi A9's
Center: Polk CSi A6
Sub: Epik Empire
Amp: Emotiva XPA-3
I would go way with a gas tankless hot water heater, but my house is all electric.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
Tom, not what I talking about and no that won't work for me. Electrical issues.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
10-4. I read it [post #4] as if you had said that you would have gone the way of gas tankless but you only had electric. Carry on...~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
If electric I would need to rewire the main breaker box, and have a 70' copper wired to a tankless tank. If gas I need to do a LP tankless tank, and I feel that wouldn't be as cheap to use it vs. the electric Heat pump hot water heater.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
My dad has a heat pump water heater.
Pros: CHEAP to run. That plus the tax credit makes it pay for itself in no time
Cons: Loud. It broke and GE fixed it... but it took forever to get the part. They Fedex'd the wrong thing about 8 times, the first guy broke something else trying to fix it, total trainwreck.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I'm definitely going tankless HWH when my conventional one goes. Germany has had this technology for over 30 years--don't know why it took the US so long.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
They're cheaper to run than conventional electric water heaters, how much...???
You'll get some additional A/C to boot. Granted, it'll only be in the space this thing is located, but...I'm sure every little bit helps in central FL.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Thinking it should be about $300 saving per year, and the AC cooling would be nice since it's in my garage.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Orlando? Solar any possibility?
disneyjoe7 wrote: »Thinking it should be about $300 saving per year, and the AC cooling would be nice since it's in my garage.
A conventional 40 gal. tank is $300, heat-pumps are $1,400+ so that saving wont show up for 4+ years.
I'd talk to whoever your A/C guy is, because he'll be fixing it, and then the local utility, to find out about rebates, etc.
Good luck.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
My neighbor had a solar hot water system, and she stated that it didn't make a nice reduce pay for electric bill. But I like my solar pool water heater system...
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
