Sub Question
Outpost
Outpost Posts: 1
edited August 2003 in Speakers
I am pushing a pair of SDA-SRS 2.3's and looking to upgrade the my system for HT 5.1 setup. Since the 2.3's have good sounding bass I am not sure whether adding a sub would enhance the sys. I am also looking at adding the CSI40 Center Channel. I plan on trying my Allison CD-6 for the rear channel. Any sugg/rec?
Post edited by Outpost on
  • twochannel
    twochannel Posts: 170
    edited August 2003
    Buy a sub! I just added a PSW505 to my 5.1 system including my SDA-SRS's and I'm very pleased. I don't plan to use it with two channel music sources. SDA's were not meant to reproduce "blow the windows out" sub-base that home theater effects have. I have a CS400i as my center and FX500i's for surrounds.They are not a perfect timbre match, but come close enough for HT. You may want to get some opinions on the timbre match from Polk or other members on the CS40i.
  • organ
    organ Posts: 4,969
    edited August 2003
    Where's Dr. Spec? He knows a lot about subs. I'm sure adding an SVS to your system will enhance the experience. They will dig deeper than your mains.
    Maurice
