SDA-1a audition
newbie308
After about a year of buying the components needed to rebuild the crossovers (read lack of funds), I finnaly hooked up my SDA-1A speakers. I feel like I've entered manhood at age 42 I'm no longer an SDA virgin! The ordeal was an uphill battle, but the end result was spectacular. I think I need a cigarette, and I don't even smoke! I read many of the posts on this forum, and drew from them what I could (The schematics were invaluble. thanks!). The result was well worth the effort and the wait. Now I can drive my wife nuts with the eternal system tweeking to discover perfect sound!
My meager 2 channel system consists of:
Thorens TD280 turntable
ADCOM GTP-500II
Carver TFM-35
POLK SDA-1A signature speakers
My first attempt ended with a series of blown fuses, so I started pulling crossovers and speakers back out of the cases and found the both tweeters in the right speaker case had loose magnets? The magnets were pinching the voice coils, and shorting them. I went to my shop and made some brass shims to evenly space the magnet cores while I reattached the front plates with super glue. The repair seems to have worked, but the tweeters work but they sound scratchy, so I need to replace them. Is it worth upgrading all the tweeters to peerless, or should I stay with the original
SL1000's and only replace the two in question?
ADCOM GTP-500II
Carver TFM-35
Sources: Technics SL1200MKII | SME3009 Tonearm | Monster Alpha 1 MC cartridge | Oppo UDP203 disk player | Nikko NT-790 analog tuner | Musical Fidelity Trivista 21 DAC | Preamp: Threshold SL-10 | Amplifier: Threshold Stasis 2 | Speakers: Snell Acoustics C/V | Kimber 12-TC bi wire speakers | Analysis plus Oval 1 preamp to amp | Wireworld Eclipse 7 DAC to Preamp | Wireworld eclipse digital IC Oppo to DAC | Audioquest Quartz tuner to preamp |
Post edited by newbie308 on
I would replace them. I had SL1000 and they are horrible.
There is a Polk Replacement but you need to do some woodwork to make them fit correctly. The RDO-194 is the Polk replacement.
I have seen others speak about a Peerless copy but i have not had ears on it. It is not a peerless merely a copy.. -
Thanks I'll look into those. How extensive is the woodwork? These cases are beat (not by my hands), so I don't mind cutting into them if needed.
I was considering recovering these cases with new veneer, but the corners are seriously dammaged, and I'm not sure what would make a good substrate to fill the dents (Bondo?)! Maybe I will keep an eye out for someone selling cases and just replace these.Sources: Technics SL1200MKII | SME3009 Tonearm | Monster Alpha 1 MC cartridge | Oppo UDP203 disk player | Nikko NT-790 analog tuner | Musical Fidelity Trivista 21 DAC | Preamp: Threshold SL-10 | Amplifier: Threshold Stasis 2 | Speakers: Snell Acoustics C/V | Kimber 12-TC bi wire speakers | Analysis plus Oval 1 preamp to amp | Wireworld Eclipse 7 DAC to Preamp | Wireworld eclipse digital IC Oppo to DAC | Audioquest Quartz tuner to preamp | -
The screw holes don't line up, so you have to plug the holes that are there and drill new ones and you have to shave out some of the hole to fit the magnet through.
It isn't bad just figured i warn you.
And if you want to know, I would buy the Polk Replacement over a Peerless copy. I am certain of Polk's quality control and not sure of the copies. I trust Polk.
As far as your cabinets go, Bondo works quite well for things like this. So does certain types of wood putty. -
post #5 by promobank6 reported as spam for removalVTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Thats why I'm waiting for Larry to make some more tweeter brackets. That way i could inset the RDO's and have the bracket compensate for the new holes I'd need to drill. -
By the way I have had the same problem with my SL1000's. In mine the pole piece came unglued and pinched the VC which ruined the tweeter I bought spares until i could afford the RDO's after the XO rebuild.
