SR sub doesn't sound right
My sub just doesn't sound that great at all. I have the SR DVC 10". My custom box has 84 cu and I'm running it on the Polk 1200.1. Not sure if its my box are what but it seems to distort a bit when I turn it up. I hope its just my set up somehow. I was expecting so much more from it. Any thoughts? Would love to hear opinions. :frown:
  • kawizx9r
    kawizx9r Posts: 5,150
    edited May 2011
    If it's new, let it break in.
    You've got the DVC version, is it wired up correctly?
    Set your gains/settings appropriately?
    Btw, welcome to the forum. That's a killer sub/amp combo you've got there.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Kfx700
    Kfx700 Posts: 2
    edited May 2011
    Make sure your wiring at the subs is hooked up fully and correct. my wires werent in all the way and the same thing was happening. try making a larger box and see if it makes a difference. sometimes boomy small boxes sound wrong?
  • arun1963
    arun1963 Posts: 1,797
    edited May 2011
    What is your xover point for the sub/mid? Like already mentioned, turn the gains down.
