HD radio recommendations
JimKellyfan
I am getting delivered, mm461p and mm521's for my 1994 Caprice wagon.
I will have a direct fit for the 4x6, but will have to modify install the 5 1/4's maybe, as the hole is 6x9.
I have the stock head unit, an AC Delco that doesn't want to play most home made discs.
I have a new antenna to install (the original Chevy power antenna bought last year) as the after market antenna in place now is mediocre at best.
Any HD radio recommendations for this set up ?
I may get subs in the future, but doubtfully, if any time soon or at all.
Thanks.
Thanks.
Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar
Audio Outdoors
Shed
Shed 2
Nakamichi soundbar
Post edited by JimKellyfan on
Jim- I can't really comment much, I bought one of the $99.00 JVC head units at BB when HD first came out for her car, the HD sounds GREAT, you'll love it. Not a lot of options on the cheep HU's though.
HD NPR is the way to go! -
Unless you love what FM has to offer i'd say go with Sirius/XM over HD. Completly differend kind of animal if you will.
HD is nice and all but in reality it's the same exact thign as your FM/AM + a few more stations. Also make sure you check to see how well your area is "covered" by HD broadcast, lots of areas aren't.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
