Where can I find these tiny caps?
audiocr381ve
audiocr381ve Posts: 2,588
edited May 2011 in Electronics
Where can I order those tiny 5600p caps in the attached file? (Those are caps right? :eek:)
Post edited by audiocr381ve on
    F1nut Posts: 51,031
    edited May 2011
    What are you trying to do......why do you want to replace them? 5600pF is a very small value.
    Anyway, http://www.soniccraft.com/relcap_rte_capacitors.htm
  • adam2434
    adam2434 Posts: 995
    edited May 2011
    That's the Valab or Teradak non-oversampling DAC, right?
    A lot of folks have replaced the outputs caps (self included) in that DAC. Those are the larger, silver caps in your photo.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • audiocr381ve
    edited May 2011
    Thanks for the link. They were taken out as an experiment and lost in a move.
    Could somebody explain what kind of caps these tiny guys are? As I was looking online to find caps at that value, their was such a huge selection from ceramic disc to blah blah blah. I'm not understanding what it all means. Or is value and voltage the only thing that really matters and the material or whatever used is preference?
  • megasat16
    megasat16 Posts: 3,521
    edited May 2011
    The surface mount caps are better left alone unless you are very very good and confident with proper soldering tools.
    Most likely, the improvements are minimal from swapping these kinds of caps.
    Can't say exactly what they are used for but it depends what part of the circuit it's used in.
    What are you trying to do and what equipment are you modding?
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • audiocr381ve
    edited May 2011
    megasat16 wrote: »
    I had a friend help me with every modification. He literally ordered the parts and told me exactly where to install what. In the end, he didn't finish the job. Now I'm trying to get it back to working shape! I don't care about using audio grade caps/resistors, I just want it working again. I'm using the time to refresh my skills because I'm getting ready to do the TL mod on my SDA-2B's.
    Since I was basically a puppet in getting this DAC to where it is now, I don't have the expertise to find the right components to get it back to where it was although I vividly remember where things go.
    I have the skills and memory and I'm sure I can do this, I just don't have the knowledge of caps/resistors so I'm doing a lot of guessing :eek: Which is why I need help :)
  • hockeyboy
    hockeyboy Posts: 1,428
    edited May 2011
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • cristo
    cristo Posts: 231
    edited May 2011
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • audiocr381ve
    edited May 2011
    hockeyboy wrote: »
    I'm at Babies R Us often, no luck.
  • newbie308
    newbie308 Posts: 775
    edited May 2011
    I think this is what you want.
    http://www.newark.com/kemet/c0603c562j5gactu/capacitor-ceramic-5600pf-50v-c0g/dp/74R1794?in_merch=Popular Products&in_merch=Popular Products&MER=PPSO_N_C_EverywhereElse_None
    However, the soldering equipment is in the $200 range.
    Sources: Technics SL1200MKII | SME3009 Tonearm | Monster Alpha 1 MC cartridge | Oppo UDP203 disk player | Nikko NT-790 analog tuner | Musical Fidelity Trivista 21 DAC | Preamp: Threshold SL-10 | Amplifier: Threshold Stasis 2 | Speakers: Snell Acoustics C/V | Kimber 12-TC bi wire speakers | Analysis plus Oval 1 preamp to amp | Wireworld Eclipse 7 DAC to Preamp | Wireworld eclipse digital IC Oppo to DAC | Audioquest Quartz tuner to preamp |
  • audiocr381ve
    edited May 2011
    newbie308 wrote: »
    Thanks for the link. I ended up going with some cheap Ceramic Disc caps for Fry's Electronics. They're working great.
  • mrbigbluelight
    mrbigbluelight Posts: 9,897
    edited May 2011
    Some very useful suggestions from fellow Polkies, I'd say. :smile:
    As a rule of thumb, it would probably be helpful in the future to mention specifics of the gear the components come from. If no one has an actual schematic, it's not impossible to dig them up from somewhere.
    Helps in the "Reply" department. :smile:
