Just bought my first pair of speakers (pic)
zim18
zim18 Posts: 19
edited May 2011 in Speakers
Got a wicked deal at futureshop and plan on using them for fronts and rears until i can afford some nice towers (a5/a7). Will be buying a csia4 shortly as its difficult to find a csi3 anymore.
What do you guys suggest for a subwoofer to match these up in a small room?
Im not impressed with the psw10 but is at a steller price, the psw111 is pretty good for its size and the psw125 has some nice oomph.
Any thoughts recommendations? Thanks!
Post edited by zim18 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited May 2011
    Congrats on your speakers and welcome to the forum!
    What's your budget for all this?
    Honestly if you intend to upgrade to tower fronts, you'll want a worthy center channel to keep up so I suggest you look torwards a CSi5/CSiA6. You won't be disappointed.
    As for a sub recommendation, how small of a room are we talking here? Check out Polk's DSW Pro line-up, they're leaps and bounds ahead of the older PSW series.....just sayin'
    Anyway, again welcome to the forum. Just get ready to empty your wallet......over and over and over again :tongue:
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2011
    Congrats! The RTi's are some great sounding speakers.
    I agree with Freddy on the center channel. If you plan to upgrade your front channels to towers, you'd be far better off getting a CSi5/CSiA6. The smaller center is going to have some trouble keeping up with the RTi towers, and is mainly designed to be used with the RTi bookshelves. Not to say that the CSi3/A4 wouldn't sound good with the towers, but the 5/A6 will be quite a bit better. The center channel is a very crucial speaker. It carries nearly all of the dialogue in a movie, and generally takes care of at least 50% of the overall soundtrack. A bigger center channel is always a good idea, whenever budget and space constraints allow it.
    Of the three subs you mentioned, I'd take the PSW125. The PSW10 is "decent" for it's price...but it's really not too great of a sub. It's low bass is pretty abysmal...-3db rating of 40hz IIRC, which is pretty bad. I haven't heard the 111, so I can't comment on it's performance. The 125 is a decent little sub though.
    They seem to be temporarily out of stock around the web, but the PSW505 is a fantastic sub that can be had for a great price. It's the best of the older Polk subs. As Freddy mentioned, the newer DSW series subs are leaps and bounds better than the older PSW's.
    So what are you using to drive all of the speakers? What are you using as a source?
    By the way, welcome to Club Polk!!
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • zim18
    zim18 Posts: 19
    edited May 2011
    Currently dont have a receiver yet...i was set on an avr1911 until i heard about the new models coming out with airplay :smile:
    Waiting on either a vsx1021k or avr2312c.
    edit: Wouldnt a csia6 drown out my bookshelves?
    Im on a budget obviously so i figured id jump the gun on the rti4's as they're discontinued and i dont think the offer would of came around again
    Toolfan66 Posts: 17,339
    edited May 2011
    NO!!! then when you get the towers your all set anyways!!!:tongue:
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2011
    Welcome to Club Polk!
    You will have to calibrate the speakers so no the csia6 will not drown out your bookshelves.
    Don't forget that this is a work in progress & you should plan for the future end result.
    So take your time & plan on spending more money up front but will have a truly rocking system in the end.
    Make sure you get a reciever that has preouts for future seperate amplification upgrades.
  • zim18
    zim18 Posts: 19
    edited May 2011
    cfrizz wrote: »
    Thanks for all the feedback guys...ill more than likely pick up the csia6!
    Preouts are not something that interests me to be honest...by the time i want to dip into that kind of money ill more than likely redo my whole setup...
    That being said most midrange yamahas do have preouts yet lack some of the features im digging for!
  • kevhed72
    kevhed72 Posts: 5,070
    edited May 2011
    Like Curt said earlier...the PSW505 can be found for a steal, just keeping trolling the internet for a deal.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2011
    zim18 wrote: »
    Ah...that brings back memories! :biggrin:
    My first HT setup was 4 RTi4s, a CSi3, and a PSW303.
    You are in for some big grins of sonic satisfaction :smile:
    The CSiA4 will do fine as a center for a small room, but the CSiA6 would be 'better'. If money and the space for the center are tight - the CSiA4 will get the job done so don't worry.
    +1 to the suggestion on finding a deal on the PSW505.
    Pictures required once you get everything set up! :tongue:
  • zim18
    zim18 Posts: 19
    edited May 2011
    Erik Tracy wrote: »
    Found a good deal a sw110...For the price point its very intriguing
  • Geoff4rfc
    Geoff4rfc Posts: 2,480
    edited May 2011
    zim18 wrote: »
    Good choice on the 6. Preouts may not be of interest to you now, but things change.
    I'm developing my first HT from last year, bought my first A/V receiver last year Feb. Wasn't interested in preouts at the time of purchase and didn't even know my receiver had preouts at the time of purchase (well, I did but didn't know what they were used for and aside from the HDMI ports and binding posts, figured I'd never use them).
    Low and behold, I upgraded my speakers just shy of a year of ownership and found myself wanting to add an amp. Thank God I didn't have to buy a new receiver as the one I bought already had preouts.
    Never say never and try to be prepared for the unexpected.
    When possible, try to make your first purchase as future proof as possible.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • Hawkeye
    Hawkeye Posts: 1,313
    edited May 2011
    Don't sell the pre-outs short! THey may not be on your mind right now, but 6 months of dabbling in audio and you'll certainly change your mind and kick yourself in the rear for not listening to the folks here. It is much easier and cheaper to not need them than to find you do. If you can spend the extra dollars, buy an AVR with preouts. In 6 months you can come back and say thanks to everyone for saving you some money!:biggrin:
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • zim18
    zim18 Posts: 19
    edited May 2011
    Hawkeye wrote: »
    Gordon
    As stated im on a budget, i dont plan on having anything in the future that will be high end as such to result in buying a seperate amplifier...for what im using and plan on upgrading to will be sufficient enough by a solid receiver.
    Pre-outs are something that are 'usually' only available in higher end receivers which serve no other extra features i feel necessary to dish out the extra $$$ for...imo anyways
    That being said i still havnt narrowed down an avr :redface:
    edit: whats everyones take on upscaling? worth having or not?...going to be watching bluray 90% of the time watching movies
    txcoastal1 Posts: 13,338
    edited May 2011
    Pioneer 1019/1020/1021 all around good receiver was causiously my entire LSi setup for 2 weeks on a 1020 until my SC-35 and Sunfire showed up.
    Google around find the cheapest deal and be done...look at the specs compare to Denon, Marantz, Onkyo, and Yammies then if you can go listen and pic.
  • zim18
    zim18 Posts: 19
    edited May 2011
    txcoastal1 wrote: »
    90% Stuck on the new vsx1021k
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited May 2011
    For your RTi's, I would recommend something from Denon, Marantz or even Pioneer Elite. Non Elite Pioneer receivers always sounded a bit bright to my ears.
    Where are you looking to buy your SW110 from btw?
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • dorokusai
    dorokusai Posts: 25,577
    edited May 2011
    Out of those subwoofer choices, get the PSW125. I prefer the PSW111 because it's nice and small but it doesn't have enough low end to run an HT setup.
  • zim18
    zim18 Posts: 19
    edited May 2011
    HTguru1982 wrote: »
    Futureshop
    dorokusai wrote: »
    Yeah the psw111 packs a punch for an 8" and if your keen on size...which im not
  • zim18
    zim18 Posts: 19
    edited May 2011
    Demo'd a psw10 with some rtia1s...sounded pretty stellar and can pick one up for $90...
    What you guys think?
