7Bs pass "push" test - any need to re-gasket/Mortite?
TomB
TomB Posts: 106
edited May 2011 in Vintage Speakers
The thread title pretty much says it all: the mid/woofer moves nicely when I push the passive radiator, (in fact, it acts like it would stay all day, if I held the passive radiator) but it doesn't seem like I'm getting the same "thump" of bass that I'm accustomed to.
A little more information: I rebuilt the crossovers a while back, and I probably haven't even broken in the new capacitors yet. (Don't know if that makes a difference.)
It doesn't look like it would be a big deal to re-gasket the drivers and terminal cups with Parts Express foam gasket material or Mortite, but by the same token, I'm not inclined to mess with it if it won't do any good. (I don't like to **** with things just for the sake of doing it.)
Thanks!
Post edited by TomB on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited May 2011
    Let the cross-overs break in.
    Btw, have you changed your speaker's positioning? The common reason why others experience a 'lack of bass' when it comes to most speakers (in almost every new-to-sda-thread) was due to positioning. Bringing the speakers closer to the rear wall reinforced some of that bass.
    As for gaskets/mortite, well there are a wide variety of opinions on that one.
    I used mortite before with good results, but if you really want to step it up I'd say contact Larry (Toolforlifefan) about his custom rings that sit between cabinet and driver.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2011
    If the pushing in the passive will hold the mid out and it takes longer than 4-5 seconds to fall back in position than you don't need new gaskets or mortite.
    Just let the caps burn in. It takes about 100hrs of use to get them settled down.
  • audiobilly
    audiobilly Posts: 351
    edited May 2011
    Food for thought,
    you might want to just "secure" up the screws that hold in all the speakers, tweeters - drivers - passive radiators. Just snug em up. I am sure they are just a bit loose after the last time they were touched at the factory. Not saying torque em down, just give a bit o love to make sure they are in good.
    FWIW
  • inspiredsports
    inspiredsports Posts: 5,501
    edited May 2011
    TomB wrote: »
    Thanks!
    Sounds like you don't need to worry about gaskets with those more than adequate return times on the midwoofers.
    Larry's rings are the bomb for the best coupling of mids and passives to the baffle possible, and the current thinking is that they work best with gaskets versus Mortite.
    What caps did you use? Many take 300 hours of signal to fully season.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • TomB
    TomB Posts: 106
    edited May 2011
    Thanks, All.
    Audiobilly, I have had the drivers out in the past, inspecting the gaskets and checking the serial numbers of the drivers. I'll check the screws again.
    Inspired, I used Dayton capacitors. (Yeah, I know...) I know I don't have 300 hours on them yet. (I may not even have 100 hours, for that matter.)
    Thanks again.
    F1nut Posts: 50,841
    edited May 2011
    Negative.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited May 2011
    TomB wrote: »
    Thanks!
    Tom, I don't get that thump I'm accustomed to either. I have my speakers right up against the rear wall. Can't wait to replace the caps/resistors to see if it gives more of a "punch."
  • inspiredsports
    edited May 2011
    TomB wrote: »
    . . . Inspired, I used Dayton capacitors. (Yeah, I know...) I know I don't have 300 hours on them yet. (I may not even have 100 hours, for that matter.)
    Yeah, there's great stuff available now, but thinking it through though I'll bet new Dayton's sound better than the "Mexico" caps sounded when the speakers were brand new :biggrin:
    NAD SS rigs w/mods
    GIK panels
  • TennMan
    TennMan Posts: 1,266
    edited May 2011
    Is there a standard push test, with acceptable times listed somewhere here on CP?
  • DON73
    DON73 Posts: 516
    edited May 2011
    My Monitor 7s have new Sonicaps and Mills. I put Mortite behind the mids and the mids would stay out forever if I held the passive in. So far I've noticed a bit more clarity in the highs......more sparkle but I did change the 1000s to Peerless so that may account for the difference in the highs. I can't tell any difference in the bass. I'll be doing my 10s sometime this year but I probably won't use Sonicaps.
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
