Want small speakers
rebuy
rebuy Posts: 695
edited June 2011 in Speakers
Been looking at TSI and discontinued monitors.
Leaning toward the TSI line.
It would be for all uses, movies and music.
Not knowing these models, need your opinion, please.
Post edited by rebuy on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2011
    rebuy wrote: »
    Greetings and Welcome to Club Polk.
    What is your budget?
    You may want to consider the RTiA line of speakers - and look for a good deal from Polk's official ebay site.
    Are you looking at Towers, bookshelves, a full 5.1 or 7.1 system?
  • VSchneider
    VSchneider Posts: 443
    edited May 2011
    How small is "small" for you? Are you thinking bookshelves like Monitor 30 or TSi100?
    edited May 2011
    Welcome to Club Polk!
    Get yourself a pair of Rti-4s on the cheap--better imaging and detail than Monitor or TSI bookshelves. Cheaper than Rti-A1s and still pretty good. Can always be moved to the rear when you upgrade to an all RTI or RTI-A series!
    Surprisingly good with both music and movies with a sub!
    Take a listen...do a search. You can get a pair (new) for 150 or less...shipped!
    cnh
  • rebuy
    rebuy Posts: 695
    edited June 2011
    Got the RTI-4's for 150 shipped to my door.
    YEAH!!!!!!
    Will the Onkyo 230 be OK for powering these and 3 other speakers.
    Don't want to burn them up from using low current, low power receivers
    that don't deliver stated power on paper. You know how they inflate power
    numbers.
    Thanks for your help
  • rooftop59
    rooftop59 Posts: 8,121
    edited June 2011
    Can you give the full model number for the avr? It will make it easier to offer suggestions. I am not familiar with an onkyo 230...
    Game Room 5.1.4:
    Bedroom 2.1
