Oppo 95 Blu-ray Player
PolkClyde
To the owners of this player: have you had any problems with it.I had to send mine in for repair,or possible replacement,just got it in march. it won't play any blu-ray disk,or CD's.. it just says, "No Disk" I tried un-plugging it,cleaning the disk,same problem,"No Disk" Thanks guys,you all are the best.
PolkAudioClyde
Post edited by PolkClyde on
I have found that sometimes if i take out a disc and put in a new one it does this.If i power down and back up it reads it ok.Please let us know what they do to fix this in case any of us need to send ours back.ThanksMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Did they ask you to send it back? Firmware couldn't fix it?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
All is fine here, haven't experienced that one.Ive had my 95 since March as well, only hicup is when playing back an sacd and then trying to watch Netflix, there is no audio unless I power the unit down. Oppo is aware of this though. Some have left there units powered down for an hour and all was fine after some failures. This seemed to help regarding the no- disc issue, which one user reported on AVS forums.
Hope all goes well
yes they did,I found out,that someone else had the same "No Disc" problem... Firmware,was updated.PolkAudioClyde -
Mine works just fine so far!!!
Seems to be working fine but a bit slow at times. This is my first bluray and I haven't played any blu rays yet. I thought I read this is relatively fast for a blu-ray player.
My major complaint is playing music from a hard drive. It's not well organized user friendly or fast...but sounds egggggsellllllleeeent!Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
