PS Audio
heiney9
heiney9 Posts: 25,396
edited May 2011 in 2 Channel Audio
I moved into a new house and the main rig is finally set-up and dialed in pretty well. A few tube changes have made the system extremely listenable until I start getting curtains and other furnishings in their final spots, etc.
I plan on doing some room treatments at some point in the future, but right now I can easily live with the sound I'm getting.
The rig really has no power or noise issues but I was looking at getting the PS Audio Power Port receptical for the main wall plug for the rig. My amp would be plugged into one outlet and the APC H15 into the other outlet.
Those that have used these, is this worth the cost? I don't need a power condtioner like the Soloist.
Just wondering if the investment is worthwhile since I really don't have any power issues.
Post edited by heiney9 on
    F1nut Posts: 51,674
    edited May 2011
    I use them for peace of mind as they are a major improvement over the $2 ones that are in your typical house.
    edited May 2011
    That's basically the conclusion I've drawn, just wondered if anyone really experienced a difference. I've located a NIB unit for less than retail and, if for no other reason than peace of mind, I will get one.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2011
    heiney9 wrote: »
    I picked up a MIT Z in-wall duplex outlet - been running my sub off of it for several months. Can't say I notice a difference - biggest change was when I went with a PS Audio Power Plus PC to the sub. The outlet is....POM.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited May 2011
    I was debating to get the Power Port or the Porter Port and decided on the Porter port. It was a Huge upgrade from the stock receptacle. I got at least a 25% increase in performance from my rig ie. more clarity, extension, separation, etc.
    I'm sure either one will do the trick.
    treitz3 Posts: 19,945
    edited May 2011
    Dunno, haven't installed mine yet. I will say this, the weight and build quality are not the same as the HD type outlets. I'm waiting to get the dedicated lines put in, so I may not be much more help than this until that is completed.
