Matching center for RTA11t
Color me a little surprised that there is such an active forum for Polk audio. Nice to see. I am considering bringing my RTA11ts out of mothballs for use in my home theater system. I intend on replacing all active drivers as mine are a little tired. I always enjoyed the 11ts and to replace all the drivers will be under $300!
My question is, what would be a good choice for a matching center and surround setup? Is there anything close to the RTA11t sound in the current Polk lineup?
Thanks for the help.
Post edited by lusich on
Hello,
Welcome to the forum:)
I will suggest you to match your RTA11t's for center channel
CS245 or the CS245i; actually there is one available at ebay
http://cgi.msn.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3043116693&category=14992
and for surround look at the recent product librabry
here: http://www.polkaudio.com/home/products.php?recent=1&category=6 Then you can get one at ebay
for really cheap.
For the current Polk line up it will be the CSi40 or CSi30 since your RTA11t's that uses the SL2000 it will be better if you
will replace them with SL2000t's(silk dome).
Regards,
Har
