3.1tl problem
bluecomet
Moving my 3.1tl speakers around with the interconnect cable still attached, I banged into it and snapped the IC pin in the speaker. Anyone have any ideas on how to get the pin out. Ben you have a PM because I think it is wedged and the part may have to be replaced in the speaker. Any suggestions would be appreciated.
Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
Post edited by bluecomet on
Is this an original SDA cable you were using?? also if memory serves me right you should be able to take out the passive and push the pin out from the back side with a smaller pin, you might have to remove some hot glue to get to it.. If you need a new socket I have one here with your name on it..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
It was one of Ben's silver cables. I have a feeling I will need the new socket. Thanks for the offer.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
Does anyone have an extra pin/blade socket? Looks like I going need it.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Sorry blue it will go out Monday !!!!Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Thanks. I really appreciate it.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
As I recall Ben's IC only has the pin portion. In the pin/blade you only need the pin.
Thait is correct.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
