SDA-SRS 1.2tl Wall Brace Plug
xoaphexox
xoaphexox Posts: 247
edited May 2011 in Vintage Speakers
I installed Larry's rings in one channel and have been doing some tests. I wanted to test for air tightness so I decided to push on the passive radiator to see how long it takes the 6.5" drivers to "deflate". Ideally if it was 100% air tight they would not slowly slink back to resting position. However, when I push the passive radiator in I hear a whistle! :confused:
After a few minutes of hunting this whistle down I determined it's coming from a hole in the back of the cabinet. I believe this is the hole that the back brace would screw in to.
I presume I should plug this hole - what do the experts recommend? I do not have the hardware to screw in the hole - but I could pick something up if I knew the dimensions - and assuming this is the best solution.
Thoughts?
Thanks!!
Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
Post edited by xoaphexox on
    Toolfan66 Posts: 18,066
    edited May 2011
    all you need is a 1/4-20 button head screw 3/4 to 1" long would work fine. you can get one at any hardware store..
  • xoaphexox
    edited May 2011
    Thank you! I will add that to my list.
  • charley95
    charley95 Posts: 908
    edited May 2011
    xoaphexox wrote: »
    If you want to be real anal you could teflon tape the threads.
  • amulford
    amulford Posts: 5,020
    edited May 2011
    or just put a 1/4" rubber washer on the screw when you install it...
  • xoaphexox
    edited May 2011
    I like the rubber washer idea.
    For Larry's rings - anyone know what kind of screws he uses for the passive radiators? I am one short. Sent him a PM but I figured I would ask here in the interest of impatience.
    Additionally, does anyone know what is best used to screw them in? I was using a Torx T10 and that worked great until it broke!
  • allstock
    allstock Posts: 136
    edited May 2011
    charley95 wrote: »
    Ha Ha....I did that! Than I fabricated some bass braces. :biggrin:
    Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
    HT-Denon avr3808ci,Carver a-753x,Panasonic ae4000 projector,120" screen,ps3,wii console w/full rockband,Panamax conditioner,dbx120 subharmonic synthesizer,jvc dvd-a player, Polk RTi12 mains,Polk CSiA6 centre, Energy ES-18xl sub,two custom 10" powered subs, Def Tech bp2x surrounds(4),Paradigm monitors-rear(2)
    edited May 2011
    It's a 8-32 button head allenhead 3/4" long, also get a cheap set of standard allen key set. both can be had at any hardware store..
  • xoaphexox
    edited May 2011
    Thanks for helping out someone as ignorant to tools/hardware as I am. I hope to finish up installing the rings in the other channel by this weekend. I have allen keys that work but they are so small for that screw that I don't get good torque when I am **** in. The Torx T10 worked better but even it broke while ****.
  • xoaphexox
    edited May 2011
    I picked up the brace screws and rubber washers at Lowes.
    I was unable to find a black 8-32 button head allenhead 3/4" long screws at Lowes. I will have to try Home Depot next - they are the only two hardware stores in the area. Mom and pop places have all vanished.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited May 2011
    "Ace is the place." Ace Hardware has what you're looking for... hopefully there's one close to you.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • xoaphexox
    edited May 2011
    Thanks - used their online store locator to find one 20 minutes from my house. Will try to make it out there and report back.
