what is an "Integrated"
gmorris
gmorris Posts: 1,179
edited August 2003 in 2 Channel Audio
Could somebody explain what an Integrated Amplifier, or simply known as an Integrated, is? I am failing to see how these are not simply recievers without a tuner section.
Bob Mayo, on the keyboards. Bob Mayo.
Post edited by gmorris on
  • jcaut
    jcaut Posts: 1,849
    edited August 2003
    Receiver without a tuner section is probably a pretty good description. It's really just a preamp and a power amp combined in one chassis.
    Compared to the relatively simple receivers of the past---My old Marantz 2270 (which I don't have any longer) for example---probably don't give up much to a typical integrated amp. Modern A/V receivers have so much extra power-hogging, noise-producing junk crammed into the chassis that, if you're interested in clean two-channel reproduction, an integrated amp makes good sense.
    I've got a couple of older Pioneer integrated amps. While they're not exactly powerhouses, they sound real clean.
    Jason
