Zerodust - stylus cleaner
doctorcilantro
light use - $45 shipped Paypal Gift
This fresh approach to stylus cleaning has saved all of us from the fear of hard bristled brushes and over applying dangerous fluids. Clean your stylus simply and effectively with the Zerodust from Japan. This space-age polymer bubble allows you to simply lower your stylus onto its surface, then quickly lift the arm lever and you?re done! Watch as the stylus tip slowly sinks into the baby soft surface, leaving behind an impression with the stylus debris left behind! This unique device will last a lifetime, can be cleaned with tap water, and can extend the life of your cartridge! Comes complete with a magnifier to inspect your stylus! Our highest recommendation!
?After a few seconds, you lift the stylus, and it?s as clean and reside-free as the proverbial whistle?Upside: no potentially dangerous brushing, and no fluids!?
- Michael Fremer, Stereophile, Recommended Components Issue
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Post edited by doctorcilantro on
i'll give this a try, send me your Paypal info Doc.
Sold and ships today.
Thank you!For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
