restore or modify rta 12b's
soundfreak1
soundfreak1 Posts: 3,414
edited May 2011 in Vintage Speakers
Have a very nice sounding pair of 12b's they are ( I believe ) built in 83. No issues with them but they are getting old (like me) might like to restore some of the ele. In them but don't know where to start or if I should! Happy with the sound so I don't want to make them into something " else" but if new caps and ? Replaced what could I expect??? And where should I start? Help appreatiated. Just want to go slow and not ruin them. Thanks
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • stubby
    stubby Posts: 723
    edited May 2011
    Do they have the Peerless tweeters or the Silver Coils? If you have Peerless, I would leave them. If you have the others, I would change to RDO's (194). Most prefer the sound of the silk dome tweets.
    If you replace the original caps and resistors with same value replacements, you are not really modifying per se. When these components get some age on them, it shows. (Sounds) I personally haven't heard anyone say that replacing their crossover components resulted in poorer sound. Unless they used different values than original.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • soundfreak1
    edited May 2011
    I'm more inclined to replace cap first reveling as much of the original sound as poss. Before "altering" the speaker.at least there will be a good baseline to judge from--as I said earlier they sound very good now but I know there is loss from age. Can the orig. Cap be found or is it. Nec. To go to other brands?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • stubby
    stubby Posts: 723
    edited May 2011
    You will need to use other brands - which is a good thing. As good as they sound now, you will notice an improvement when you switch to "aftermarket" caps. Do a search on crossovers and you will find a wealth of info. What brands work well, price/performance ratio, lots of good to know info.
    FWIW, I used Sonicaps on the high end and Solens for the lows. It worked out really well for me. It would have been very cost prohibitive to use Multiple Sonicaps for the low end......just one cap had a value of 185uF! $$$$$
    stubby
    SRS 3.1TL
    Anthem AVM2
  • soundfreak1
    edited May 2011
    What can I expect to spent to replace the caps assuming I do it right (not worth doing if not right) I don't expect to get any money spent back but gotta see if it makes sense! I do really enjoy these speakers but---- I. Am speaker poor!LOL 3 pair of (mains) to rotate around according to mood . None are considered less than the polks, just diff. But I do like the polks. A lot! They seem to handle a wide veriety of diff. Music very nicely. They complament my ele. Nicely. Do appreiate the help.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
