Elemental Designs A5-300
Face
I have for sale a Elemental Designs A5-300, I would rate it an 8/10. Works great and looks like new due to it's durable finish. The only reason for the sale is that I replaced it with a much larger SVS.
Due to it's size and weight, local pick up only at this time.
For more info: http://www.edesignaudio.com/product_info.php?products_id=103
Asking $300, thanks.
Post edited by Face on
This is one bad-a$$ sub, lots of power for its small-ish footprint.
Does an admirable job even on a carpeted concrete slab, nothing to sneeze at, IMO.
If I did not already own an SVS, this would not be here after today!
Free bump, GLWTS too.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Is that sealed Mike?Samsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Let me know if you are going to get rid of your Valor....:biggrin:
touche'Samsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
They're the ported version."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
suppose if I read the link I coulda figured that out, but nothin beats a free bump!Samsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Thanks James.
FYI, price is $300 OBO."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
hows the port noise on these things with corner placement. I have a preference towards sealed designs due to my aversion to even the hint of port noise. Do you have it in the corner or more towards the center of the room next to the speaker. I'm located in north jersey so a pickup drive is doable albeit somewhat long... my other concern is how to mate it with my current sub in a dual config. Did you also manage to get the 20hz in your room. My current sub rolls off below 25hz and I'm wondering how much EQ/tuning will be required to mate the two...Fronts: Wharfedale diamond 9.6
Sub: Wharfedale sw250
Rears: Wharfedale diamond 9.1
Center: Paradigm cc-350
Pre-amp: Oppo dv981hd
Amp for fronts: Parasound hca-1500a
Amp for rears: Adcom gfa-5400
Amp for center: Marantz MA500 monoblock
Polk multimedia speakers for PC setup -
I had it approximately 3" from a side wall, and 3' from the rear wall and couldn't detect any port noise.
I was told by eD that this model was tuned to 20hz. In my room I had flat response down to 25hz, but since each room is different, you could do better or worse.
Depending on your room and placement, in general multiple subs may not net deeper response, but will definitely give you smoother response.
http://www.harman.com/EN-US/OurCompany/Technologyleadership/Documents/White%20Papers/multsubs.pdf"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Thanks. Yes, I'm aware that with multiple subs, its more about getting more output with less distortion, rather than hitting lower. the challenge of 2 subs with very different -3db frequencies is that the output is going to be somewhat variable if one digs lower than the other... Looks like a heck of a sub but I'll have to pass... GLWTSFronts: Wharfedale diamond 9.6
so tempting!Samsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Ttt..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
$250 OBO, this thing is taking up too much space."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
PM sent...dimensions?
Any chance of traveling south anytime soon. I live in the dc area and would be interested in buying.
ShawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
PM sent...I said.
Relax. The seller hasn't posted on here since before you posted your PM notice the first time... Maybe he hasn't even been online. The way it works around here is that you'd most likely be first in line, except with that attitude... idk.PM sent...I said. -
Sick price bro. GLWTS !!
^ maudioguy = funny.Shoot the jumper.....................BALLIN.............!!!!!
so tempting....great price and local too....Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
PM sent...I said.
Easy champ; let Face answer your questions and post if you're still interested. If not, I have interest in possibly purchasing this subwoofer. Is that good enough for you?Shawn
Front: Polk LsiM703
Rear: LSI fx
I'd pass and sell it to Shawn personally.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I was told by eD that this model was tuned to 20hz. In my room I had flat response down to 25hz, in general multiple subs may not net deeper response, but will definitely give you smoother response.
multiple subs are tricky the only way to get 100% from each is to have the same models and both in the same location .
I have 2 subs one in the cornor and the other (a differant one) is about 5 feet away what I found the cornor sub hit lower and with the other sub
?loud? I would still get increased volume (spl) but it would eat the lows (20-30 hz) .
So its kinda a game get the other sub to blend if it wont just keep the better one . -
is it sold or available ?Fronts: RTi 8s
Center: CSi 5
Rears: RTi 4s
Receiver: Onkyo TX-SR705
Subwoofer: Elemental A3-250 and SVS
Light: Epson Home Cinema 8350 -
If Mike decides to ship, I would want to buy it. I think he is looking for a local sale due to the size and weight of this thing, though.Shawn
Front: Polk LsiM703
Rear: LSI fx
Mike, whenever you decide to go into the city and you still have the sub then, hit me up. ThanksOnkyo 805, RtiA5s, Csi5, Rti6s
