timbre matched center speaker to Atrium 55
tman7078
I just completed a three season room and need to add a center channel to my system. I have Polk Atruim 55 in the front and Atrium 45 in the rear. I have the tv mounted above the fireplace and would like to a center speaker. Do you have any suggestions on a center speaker that will be trimble matched to the 55?
CS350LS, CS400 or CS400i would all work pretty well. All have similar tweeters. Welcome to CP! -
Ken,
Thank you for the recomenndation. I looked at the specs of these center channel and they are very deep. I would like to find something smaller as I plan on mounting this under my led 42 tv that is mounted on a stone wall. Any other suggestions?
John -
You mean timbre matched I'm assuming.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Ken,
John
Each of the centers I suggested have smaller ones down the line but IMO you don't want to skimp on your center. Do much of the HT experience comes from it. Any way to mount a shelf of some sort above or below the TV? Room for a stand? Post pic's of your setup...I'm sure we can help you figure something out. -
I have the CS400i, and really like it. I had the CS245 before it, and while physically smaller, the CS400i sounded remarkably better.
Here is a pic from my phone
Ken, I am leaning towards the CS10 as it has 5 1/4" woofer and 1" like the Atrium 55's. Are these going to be timbre matched?
