anyone out there do any video editing?
lonney
lonney Posts: 27
hi gang just got a new panasonic dv cam and im having problems with windows movie maker everytime i go to add an effect it just shuts down no error messages it just goes away any one have the same problem or can recommend a really good video editor?...Thanx for your time gang!
MY SETUP:
Hitachi 43"FWX20B HDTV Widescreen
Panasonic SA- HE100-Receiver
Paisley Research Ref 1-Fronts
PolkAudio CSi40-Center
PolkAudio R15's on stands-Rears
PolkAudio PSW 202-Sub
All Monster Cable THX Cert. 16Guage spk wire
All Monster Cable THX cert. Connections
JVC XV-N44 DVD W/Monster THX cert.Component and Optical Cables
Post edited by RyanC_Masimo on
  • GuitarheadCA
    GuitarheadCA Posts: 400
    edited August 2003
    hmmmmm, I've used windows movie maker quite a bit, and havn't had that happen. There is a Windows Movie Maker II out, you can get it through windows update. If that doesn't work, then there's a slew of video editing programs out there. I use Adobe Premiere which is considered by many to be the industry standard (head to head with Final Cut Pro). However these two are *not* cheap, and so you have to either have to know someone or part with some cash. I've also used an editor called "Dazzle" which came with my Firewire card, It doesn't hold a candle to Premiere, but hey, it was free.
    VR3 Posts: 28,818
    edited August 2003
    If you are using windows XP and are using Movie Maker and it justs *shuts off* then XP is doing what I call......Flushing the Memory
    Does your entire computer sorda do a on-screen live time reboot without actually doing a reboot afterwards?
    OH BTW - if so, this is a lack of RAM and Harddrive space :cool:
