Harmony device layout question
Ron-P
I have a 676 with 5 devices programed in. I want to change the layout on the screen so the first 3 devices come up and I don't have to hit "next" to get to one of the devices I need on the first screen.
Is there a way to move these around?
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
yes or there should be. When you launch to program on your PC with the Harmony connected you should see under activities a way to sort order.Speakers: SDA-1C (most all the goodies)
I will try that next time I plug it in, thanks.If...
