really new and could use some advice...
byfthalone
byfthalone Posts: 345
edited April 2011 in Speakers
as it says in the title I am new to building anything to do with audio and I do have a couple of questions. my setup so far consists of a Denon avr-791, (2) Polk TSi100, CS10, PSW110. I am now looking to add the remaining speakers. should I stay with the TSi series and just go with the TSi300/400 for the fronts? I did see a pair of RTi A3 on ebay that were reasonably priced. Would that make sense?
Been reading the forum for a couple of months and have learned so much from all of you, thanks for that and for any of your opinions/advice.
Post edited by byfthalone on
  • punk-roc
    punk-roc Posts: 1,150
    edited April 2011
    looks like the OMW3's are the recommended surround for the TSi's.. have you looked at those?
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • punk-roc
    edited April 2011
    oh, you are looking for speakers to add for the fronts? going with the TSi floor-stander seems reasonable enough to me..
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2011
    I would stick with the TSI series. The only this is if you do the RTI line for the fronts you really should change out your center channel so it will all timbre match. Normally if your doing HT you want the front 3 to be match and the surrounds can be different.
    So if you did the A3's look at the center channels as well and if go that route move your current speakers to surround duty. You can always upgrade or change those later if you want.
    otherwise the TSI or Monitor series (little bit different for look but sound very very similar) could be used. This could help you save some money if you want and you could look at doing the Monitor 30's and they go up to the largest floorstander of the Monitor 70's. However if doing the floorstanders I would also recommend changing the center to the CS2 or CS20 for improvment there as well.
  • djperez81
    djperez81 Posts: 388
    edited April 2011
    cstmar01 wrote: »
    What he said:biggrin:
    I would get the 400's or some monitor 70's and put the 100's on surround duty, and maybe look at getting a better center.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • byfthalone
    edited April 2011
    thx...I get a pretty decent accomodation from work so I'll go with the 400's. if I can ask, what does the CS10 center lack that it would need to be changed out?
