Wright WLA 12A with many mods---650.00 Shipped Conus
george daniel
This is a killer little pre--first off it comes with a 6x5 rectifier--Mullard CV 574 that I purchased about 18 months ago--Sylvanis 6EM7,,and two Baldwin labeled Sylvania 6SN7's,,from Jerryj12's historic first organ pull.I replaced the captive power cord with Carol Cable and a Pass & Seymour Plug,, next,the output coupling caps are VH Audio-PIO's,bypassed with Russian K-40Y's(.022),,a Mundorf in the power supply finishes things up.It has a "stepped" attenuator.I removed the "balance" control,, I can replace it if you like,but felt that it was unecessary for my application.Aftermarket "spikes" on the base--it's missing a few screws on the bottom plate. It has plenty of inputs,,a mute--hi/lo gain switch on the back.The unit was assembled by George Wright(RIP),,in 2000.I have agonozied over selling this,but the fact is,I ain't using it anymore.This unit is kinda like the Dodd ELP in the sense that you don't have to use too much volume control.These are not made anymore,so they are becoming few and far between these days.Price is more than fair--so please,,no pm's with "offers".PM if innarested.Thanks for looking.
Edit-- this is a linestage only.Specifications
Very Linear 6SN7 voltage and driver stages
Frequency Response: Better than 20 Hz to 20 kHz , plus/ minus 1 dB
Distortion: Less than 0.4 percent total harmonic distortion
Input Impedance: 100 kilohms, nominal
Output Impedance: 2 kilohm, nominal; will drive loads down to 600 ohms with some loss of output level
Voltage Gain: 12 to 20dB, switchable on back
Noble designed Audio reostats
VH audio caps ? in signal path of the line stage
Tube rectifier and regulation for truly quiet operation
Output Level: 2 volt PP nominal; will drive up to 20 volts PP
Stereo-mono-stereo reverse switch
Output level control: 0dB- -10dB- -Full mute
Tape record and playback compatible
Size: 6 x 10 x 5 inches
Post edited by george daniel on
Where are my manners,,,-- comes with spare 6EM7's and 6X5's too-- US Navy 1943-Raytheon and a Tung Sol circa 1953--
Guys-- lets make this 600.00 shipped--I was wrong in my original price.JC approves....he told me so. (F-1 nut) -
Solid seller and preamp.Speakers: SDA-1C (most all the goodies)
dont even know what half the stuff you mentioned is, but knowing your rep, i bet its nice.
Maybe someday, gives me something to dream about.
good luck with sale george.humpty dumpty was pushed -
Nice, nice, very nice! But, no $, just trades
Now if someone buys my N2X's then game on!! Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
As always George, very nice.
550.00 shipped Conus-and you replace the balance control--I'll send it along with the unit.JC approves....he told me so. (F-1 nut)
PM sentMain Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
I am interested in this. Did you sell it yet?
thanks
ken99 -
