6 ohm stereo and 8 ohm speakers? Will it work?
packetjones
packetjones Posts: 1,059
edited June 2011 in The Clubhouse
I am looking to get my parents some of the new TL series speakers and they currently have an old phillips bookshelf system that we can not really afford to replace at this time. I looked up the system and it is a Phillips FW775. It is listed as 6 ohm speakers for all the but the center channel and 12 ohms for that. I know that all of the TL's are 8 ohm and was curious if it would be ok to connect these to this old stereo.
I thought who better to ask then the folks here. Would it be ok?
Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
Post edited by packetjones on
  • packetjones
    edited April 2011
    Bump...
    Any opinions? i know that it is not ideal but was curious if i run the chance of damaging anything.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited April 2011
    Hello PJ,
    Your parents should be fine. It's distortion, no matter what the cause, that's harmful to speakers. Just tell them if they hear a fuzzy or harsh quality to the sound to reduce the playing volume until it goes away. In all likelihood that won't be a problem and they will enjoy the extra clarity and definition.
    Enjoy, Ken
  • packetjones
    edited April 2011
    Thanks Ken I appreciate the info. Looks like they may be getting a TL surround setup soon!!
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • [Deleted User]
    edited April 2011
  • packetjones
    edited June 2011
    So new development. I was able to score a pioneer vsx816 from a fellow polkie. I will have to keep the speakers for a little longer. Anything to worry about when running the 6 ohm speakers from an avr?
    My last question was the opposite scenario. Maybe I just don't understand ohms. I know that the less ohms the harder it is to drive, but that's about all. Any advice would be appreciated.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
    treitz3 Posts: 20,017
    edited June 2011
    Here's where you run into possible issues. If the AVR is rated at 8ohm and you are running 6ohm speakers, you run the risk of blowing both at loud and extreme volumes. At lower volumes you should be OK. Just be sure to follow the advice headed by Mr. Swauger.
  • packetjones
    edited June 2011
    Thanks. I will begetting some speakers soon. I just couldn't pass up the pioneer I got. Used the money I was going to spend on speakers for it.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
